swapped from cx to dx
Old Jul 29, 2002 | 11:25 AM
hmonglonertim's Avatar
Default swapped from cx to dx
Has anyone ever done or has an eg like this. The motor was swapped at the shop I bought it from. It's a bone stock dx motor but it feels like it's got a big turbo. I've tried new spark plugs (helped a little), timing, plug wires (oem), fuel filter, oil and filter, cap and rotor and it still runs under par. Any suggestions. I can't afford a b series motor at the moment and I do have a cx motor I could swap but I'd rather keep the dx. How hard would it be to swap the cx motor back in the cx chassis? Thanks.
Old Jul 29, 2002 | 11:38 AM
owen_the_soyboy's Avatar
Default Re: swapped from cx to dx (hmonglonertim)
cx motor =
cx tranny =
save up and get a nice fresh EX/Si D series swap or figure more out about what you DO have in the car
Old Jul 29, 2002 | 05:25 PM
.nate's Avatar
What do you mean by this? Do you mean that the car starts out sluggish but towards the top of your powerband the car starts to pull better?
Old Jul 29, 2002 | 06:48 PM
madhatch's Avatar
Default Re: swapped from cx to dx (N8)
what tranny do you have? Also try to advance the timing. Use premium fuel and bump up the timing it will help out on the bottom end. Try and get an ex or si tranny also. The lower final drive will give you good bottom end and you will like the "power" better.
Old Jul 29, 2002 | 06:59 PM
EKB18BPR3's Avatar
Default Re: swapped from cx to dx (madhatch)
u gotta dx motor but u wanna go to cx? are u nuts? cx got like 20 hp less than dx...and yeah save up for b16's
Old Jul 29, 2002 | 09:02 PM
Vanilla4215's Avatar
Default Re: swapped from cx to dx (dniedacess)
You probably still have the cx tranny.
Old Jul 29, 2002 | 10:28 PM
D16Z6racing's Avatar
Default Re: swapped from cx to dx (Vanilla4215)
I did that swap at first cause my CX head gasket was bad. My felt like crap in the beginning too. DX motor, CX tranny, and CX ECU.....once I got my DX ECU, everything was fine. All I added was new plug wires, cheap ones from the near auto parts store.
Old Jul 30, 2002 | 12:36 PM
Default Re: swapped from cx to dx (buster13)
I did that swap ....... once I got my DX ECU, everything was fine
sounds about right
Old Jul 30, 2002 | 01:15 PM
While you were running the cx ecu did it throw any error code?
tncivic-dvsb
13
May 27, 2006 12:15 PM
dispnoiracer
May 1, 2006 09:49 AM
tyronebiggums
18
Apr 1, 2003 08:41 PM
Who Said
23
Mar 24, 2003 07:13 PM
hmonglonertim
Jul 31, 2002 05:58 AM
