Installing Oil Gauge...?
Old Oct 21, 2008 | 07:42 PM
DJSurfer616's Avatar
Default Installing Oil Gauge...?
I am planning on installing the auto meter oil gauge I bought in my dc2. I am planning on putting it on the opposite side of the light illumination next to the steering coulmn. Havent seen a write up onhow to do this or where to connect the gauge for it to work....help...
Miguel
Old Oct 21, 2008 | 10:10 PM
boosted96teg's Avatar
Default Re: Installing Oil Gauge...? (DJSurfer616)
get a "T" fitting, unbolt your oil pressure sensor on the back of the block, screw in the "T" fitting and than screw the sensor on the open end of the fitting and your set.
Old Oct 22, 2008 | 06:45 AM
AWD Terror's Avatar
Default Re: Installing Oil Gauge...? (boosted96teg)
I feel like the sped teacher in school.
Three seconds of searching:
https://honda-tech.com/zerothread?id=2408757
https://honda-tech.com/zerothread?id=2019826
Old Oct 22, 2008 | 07:59 AM
steveharrmr23's Avatar
Default Re: Installing Oil Gauge...? (AWD Terror)
are you talking about using the whole where the cruise control switch would be if so you can take a whole saw either 2" or 2 1/16" the later of the two is prefered but the 2 will work and drill it out but first you want to cut the dash material away
Old Oct 22, 2008 | 11:11 AM
Thanks AWD that was perfect...guess I didnt search right. Thanks for the great help bro.
EFityo
Feb 17, 2011 04:48 AM
*Boostwerks*
10
Dec 3, 2008 04:39 PM
5STAR3
May 6, 2004 05:40 AM
miketurbohonda
Apr 27, 2004 06:52 PM
B18 rider
Nov 21, 2003 02:42 PM
