Gain power by remaping my ecu, Possible?
Old Oct 21, 2008 | 11:37 AM
rcfranky's Avatar
Default Gain power by remaping my ecu, Possible?
Is it possible to gain power on a stock D16Z6 just by changing maps on the ecu?
Old Oct 21, 2008 | 01:56 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: Gain power by remaping my ecu, Possible? (rcfranky)
hardly if any, thats not worth doing it. The stock map is designed for maximum efficiency out of a completely factory set-up. Look into getting I/H/E first and depending on the set-up on the I/H/E you get, you can tune that.
Old Oct 21, 2008 | 03:50 PM
rcfranky's Avatar
Default Re: Gain power by remaping my ecu, Possible? (JDM turbo DC)
JDM, what does mean or what do you mean with I/H/E?
Old Oct 21, 2008 | 03:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcfranky &raquo;</TD></TR><TR><TD CLASS="quote">JDM, what does mean or what do you mean with I/H/E?
Intake/Header/Exhaust, your basic bolt-ons
Old Oct 21, 2008 | 04:00 PM
rcfranky's Avatar
ok, what gain could i have by taking off Cat? is it worth?
About intake, and talking about NA what should i do? dont want to go turbo right now, i've experienced that, i loved it but at this moment i'm just looking for a non trouble setup. What's your advice?
Old Oct 21, 2008 | 09:00 PM
kicked25th's Avatar
even a bone stock car can gain from a chip.
I know personally i noticed quite a difference both in HP and MPG, though i/h/e will help.
Using p08 timing on a d16z6 with an extra degree up top and 1-2degrees in cruising completely changes the feel of the car. I know. Ive tested it.
Modified by kicked25th at 10:27 PM 10/21/2008
Old Oct 21, 2008 | 09:09 PM
Default Re: Gain power by remaping my ecu, Possible? (kicked25th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kicked25th &raquo;</TD></TR><TR><TD CLASS="quote">even a bone stock car can gain from a chip.
I know personally i noticed quite a difference both in HP</TD></TR></TABLE>
was this on a dyno?
Old Oct 21, 2008 | 09:28 PM
kicked25th's Avatar
Most people dont dyno cruising hp, but the answer to your question is no, it wasnt.
Top end was verified by track times and trap speeds, which if you ask me, are a better representation than dyno numbers.
Is it worth a tune? No. A basemap? Yes.
My car runs on my "bench" map but Id be willing to BET that it makes more power on the dyno.
gringo7718
Engine Management and Tuning
Nov 9, 2008 03:49 AM
nahonda04
Sep 19, 2007 09:30 AM
LuE630
11
Jul 7, 2007 07:39 PM
2fast2bad
Dec 4, 2003 03:20 PM
N1-R
Nov 3, 2002 05:45 AM
