manual fan switch help??
Old Oct 21, 2008 | 10:30 AM
turbosivtec's Avatar
Default manual fan switch help??
Hi I have crx and my fan aint coming on, while my temp rise like crazy....so I was wondering how to hook up a manual switch for the fan..so that it could come on when you wanted to??...what size switch amps is best..where should i hook it too??..any advice would be helpful thanks
Old Oct 21, 2008 | 10:40 AM
Ermil's Avatar
Default Re: manual fan switch help?? (turbosivtec)
Why not repair it correctly and install a new thermo fan switch? That's most likely the problem.
Old Oct 21, 2008 | 11:34 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: manual fan switch help?? (Ermil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Why not repair it correctly and install a new thermo fan switch? That's most likely the problem.</TD></TR></TABLE>
agreed.. don't be like the jackass who owned my car before me.. would you rather spend 10 minutes and a coolant top off to replace the switch, or 3 hours figuring out why the genius wiring job you just did makes your car smell like electric fire.
Old Oct 21, 2008 | 11:47 AM
wheres the thermo fan switch located at???..
Old Oct 21, 2008 | 12:20 PM
HaulingAddison's Avatar
It's the 2 wire sensor on the back of the block below the intake next to the oil filter.
Old Oct 21, 2008 | 06:19 PM
zrickety's Avatar
Default Re: manual fan switch help?? (HaulingAddison)
could also be the relay or fan went bad. make sure it works with power.
having had a car with a manual switch, it's best if the original system still works. i used a plain switch and relay to power the factory relay on the car. that way it came on by itself, or when i hit the switch.
but in my current crx, i think a switch is dead weight. the fan comes on when it's supposed to
Dunc
Sep 19, 2007 08:54 AM
LukieLuc
Jun 12, 2007 05:46 AM
platinumx6
Apr 9, 2007 02:59 PM
85
Sep 3, 2006 03:02 PM
wardstar
Aug 30, 2004 01:45 PM
