Blew my turbo, need a new one, help me out with choosing the best please (info inside)
hey guys, well i blew my turbo due to oil starvation, used too small of an oil restrictor, 0.040 on a non ball-bearing. So i took it to a shop and they said its not worth rebuilding cause the only thing that they can save is the housings, the wheels are both messed up. So the turbo was Garrett T31/T04B "60-1" Stage 3 Turbine (75 trim), 0.70 Comp A/R, 60 Comp Trim, 0.63 Turbine A/R. Now im thinking of going non-ball bearing again, im shootin for MAX of 420whp, the car is daily driven. Below is my complete setup, the car is a 91 accord with 2.2L F22A6 SOHC please help me out with choosing the right turbo
Thank you very much
Block, head, motor:
* Built head (f22a6 SOHC)
--- Some Port and Polish
--- 3 Angle Valve Job
--- Flat Mill Decks
--- New valve seals
--- Crower Acura RSX Dual Valve Springs (custom fitted)
--- Crower Acura RSX Titanium Retainers (custom fitted)
--- Ferrea 30mm Exhaust valve, 5.46mm stem, 123.55mm OAL
--- Ferrea 33mm Intake valve, 5.48mm stem, 112.10 OAL
* F22 block, stock sleeves, bored to 85.5mm (0.5mm over)
* Balanced rotating assembly
* Delta 260 Camshaft
* AEM TruTime Cam Gear
* Wiseco Forged Pistons 8.8:1 CR + Rings + Pins, Custom made to work with H22 rods in my F22 block with F22 pistons
* Eagle Forged Rods (H22 H-Beam ESP)
* ARP Headstuds
* ARP Main Studs
* ACL Main and Rod bearings
* New OEM Headgasket for F22 (works with the 85.5mm bore)
* New OEM Waterpump and Timing Belt
* New OEM Crank pulley, Seals, O-rings, Gaskets, Thrust washers, Hoses etc.
* Toga High Volume Oil Pump
* AEM High Flow Fuel Rail
* Extrude Honed (extreme port and polish) f22a6 Intake Manifold + Bored out TB
* Bisimoto Intake Manifold Gasket
Drivetrain and Misc:
* F22 5spd tranny out of 5th gen accord
* OBX LSD
* Action Clutch, 2MS Dual Diaphram Clutch, 6 puck miba friction pads sprung disk
* Bisimoto 8.9lbs Aluminum Flywheel with heat treated friction plate
* Stock F22 axles
* ESP Traction Bars, and torque mount
* ESP Motor Mounts
* Aeromotive 10 Micron Inline fuel filter
* Fuel Hardline to AN Converter, AN fuel lines, AN fittings, AN hose ends. Complete AN hardware from hardline to Fuel rail.
* Oil Catch Can, 10 AN Valve Cover Weld On bungs, 10 AN Lines, 2x 90 degree hose ends, 2x straight hose ends
Turbo setup:
* Garrett T31/T04B "60-1" Stage 3 Turbine (75 trim), 0.70 Comp A/R, 60 Comp Trim, 0.63 Turbine A/R, + Downpipe Flange
* OBX Ramhorn Turbo Manifold
* 38mm TIAL wastegate with 1bar spring + Mild Steel Flange
* HKS SSQV Bov 2007 Redesigned
* HKS Weld-On Flange (alluminum)
* JRC 8" Intercooler
* 2.5" Intercooler Piping (ebay aluminum)
* AEM Fuel Rail
* Golden Eagle Vacuum Manifold
* GM 3 bar MAP Sensor
* Wideband Innovative LC-1
* Stealthmode Oil Line Kit & Oil restrictor
* Defi BF Gauges, white, Oil Pressure, Water Temperature, Boost
* Fuel Pressure gauge on fuel rail
* HONDATA S300 with boost solenoid
* Walbro Fuel pump 255lph High Pressure
* Precision 880cc Fuel Injectors
* Mishimoto 92-00 civic Aluminum Radiator Half size
* 12" Slim Fan
Thank you very much
Block, head, motor:
--- Flat Mill Decks
--- New valve seals
* ARP Headstuds
* ARP Main Studs
* OBX LSD
* Stock F22 axles
* ESP Motor Mounts
Turbo setup:
* AEM Fuel Rail
* 12" Slim Fan
oh ya my hot side is turbonetics, i bought the turbo from blaastperformance, and i had to rebuild it right after i bought it, the wheel wouldnt spin freely, i was NOT happy at all with the service or the product. It looked like it was slapped together.
Anyways my exhaust housing looks like this, and my downpipe is made to fit this, so im hoping to get the same type turbo, or is this gonna be very unlikely?
Could you point out what "this" and "this" are in your enclosed photo. It is confusing and vague.
hey sorry, im pointing out that my downpipe is 5 bolt, like the housing on the left. Its a Turbonetics exhaust housing with 5 bolt downpipe. I would like to get a turbo that has this also, so i dont have to cut and re-weld a new downpipe flange.
PMed back
I was browsing through sponsor's marketplace and found these turbo's for sale, which best suits my needs?
466159-5004 - T3/T4 - AR .63 - 60 Trim
466159-5003 - T3/T4 - AR .63 - 57 Trim
466159-5005 - T3/T4 - AR .48 - 57 Trim
T3/T4 AR .48 5-bolt 50 Trim
T3t4 AR .63 4-bolt 50 trim
T360-1 .63AR t04s
T3 super 60 5bolt discharge
T360-1 .63AR t04s
TURBONETICS they all come with a no question lifetime warranty. I run a t3/t4 .48 trim stage 2 ceramic ball bearing turbonetics turbo. No problems from it yet,but you gotta love tht warranty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa »</TD></TR><TR><TD CLASS="quote">TURBONETICS they all come with a no question lifetime warranty. I run a t3/t4 .48 trim stage 2 ceramic ball bearing turbonetics turbo. No problems from it yet,but you gotta love tht warranty</TD></TR></TABLE>
I hate to sound like this, but the reason why there's no questions asked is because you'll be sending it in constantly. In addition, Ceramic ball-bearings tend to disintegrate over time. That's one of the reasons why other turbo companies stopped using them by about 1996. They were big in the 80s, though.
Now the larger units over 76mm are a bit of better quality.
aleks77
Nov 13, 2006 12:35 AM
4661595003, 4661595004, 50, 5004, 60, garrett, honeywell, oil, restrictor, stage, t31t04b, t3t4, trim, turbo, turbonetics
