NGK spark plug ?
Old Oct 20, 2008 | 09:15 PM
accord99power's Avatar
Default NGK spark plug ?
I bought these NGK BKR6EIX-11 3764 Iridium IX for my stock block t3/4 turbo setup with 550 injectors, more specs listed in signature. heres the ?
I looked at these plugs they look like 2 or 3 steps colder then stock. I'm pushing 60+ whp over stock and 100+ troque over stock. Will to cold of a plug damage my engine? Anyone use the plugs i mentioned before? please help
Old Oct 20, 2008 | 09:43 PM
dpetro1's Avatar
Default Re: NGK spark plug ? (accord99power)
heat range 5 is stock so you are one step colder. that should be fine. if you are having pre-ignition problems then move up to 7's
Old Oct 20, 2008 | 09:59 PM
Default Re: NGK spark plug ? (dpetro1)
thanks man, i have been doin some research and your right from what im readin they should be good, the autozone guy didnt know what the hell he was talkin about he was full of . go figure right
Old Oct 20, 2008 | 11:36 PM
dansred2000si's Avatar
my tuner supplied the plugs and used R5671A-9's and i plan on using these but any thoughts?????
Old Oct 21, 2008 | 04:32 AM
dpetro1's Avatar
Default Re: (dansred2000si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">the autozone guy didnt know what the hell he was talkin about </TD></TR></TABLE>
yeah i dont expect them to know much about FI hondas anyways, better to do your own research.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dansred2000si &raquo;</TD></TR><TR><TD CLASS="quote">my tuner supplied the plugs and used R5671A-9's and i plan on using these but any thoughts?????</TD></TR></TABLE>
what EMS, what whp, what motor? those are non-resistor race plugs and pretty cold too. probably not really needed and will foul quickly
Old Oct 21, 2008 | 04:48 AM
19slocivic97's Avatar
Default Re: (dpetro1)
my tuner recommended NOT to use the iridium plugs, he claimed they dont move heat away from the electrode like a conventional plug.. so i run the bkr7e and there cheap enough that you can change them often
Old Oct 21, 2008 | 07:07 AM
ralph11sec's Avatar
Default Re: (19slocivic97)
i love ngk regular ones with colder heat range. cheap and very reliable.
the iridiums get foul easily when tuned a little rich. like 12s/13s at idle.
Old Oct 21, 2008 | 03:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">
what EMS, what whp, what motor? those are non-resistor race plugs and pretty cold too. probably not really needed and will foul quickly</TD></TR></TABLE>
s300 350hp on built ls vtec
Old Oct 21, 2008 | 04:29 PM
dpetro1's Avatar
bkr7e for sure. hondata will highly recommend against non-resistor plugs
http://www.hondata.com/techksparkplugs.html
Old Oct 21, 2008 | 08:06 PM
i installed them, for alittle while i high stumbling at 32mm gap, i ran for awhile and it went away, kinda strange, ill see what happens tommorrow.
yoffer
17
Aug 1, 2007 06:21 AM
2001accord
Jul 7, 2005 03:24 PM
Jcup315
Apr 18, 2005 06:08 PM
Trailz-EX
Jan 23, 2005 01:33 PM
Aeka GSR
Dec 5, 2003 10:14 AM
