need diagrams for h22a swap!!!!!!!
I just bought a prelude 4WS that was swapped to a h22, vtec does not work and I have the presure switch and the siliniod wired to the correct pins on the ecu but still no vtec. My rpm gage and speedometer doesnt work either, could that have anything to do with it? either which way I need the diagrams to make sure the knock sensor is wired. if anyone could tell me which wire works the tach from the distributor that would be great. I'm open to any suggestions
I have my vtec siliniond wired and I also have the pressure switch hooked up, the knock sensor is wired like normal, but still no vtec! any Ideas?
vtec will not work without speed sensor. do a search for "vtec not working" that should help you out, but I know from experience it wont work without vss (vehicle speed sensor) easy fix.
lemongreenhatch
Jun 12, 2004 08:15 PM
