oil burned after event....
Old Jul 29, 2002 | 09:27 AM
TaboR's Avatar
New User
Default oil burned after event....
went to The Street of Willow last Saturday
and got home for a oil change, one full quart. of
Castrol syn 5w-50 is gone...
but this is not the worse...!!!
back in June, after a event in Fontana, i burned two quarts of my
Mobile Syntech 5w-30
are this normal to every of u that go to track???
and which grade of oil is better for street/track use?
[Modified by FreddyR, 10:32 AM 7/29/2002]
Old Jul 29, 2002 | 09:30 AM
Chubz's Avatar
Default Re: oil burned after event.... (FreddyR)
lots of time in VTEC=Lots of oil burnt
I lose about 1 quart every 1000 miles, hard driving. Did a compression and leakdown test and everything was fine. Have no clue where it went
Old Jul 29, 2002 | 09:43 AM
Willard's Avatar
somewhat normal...
mileage?
have you replaced your PVC valve?
catch can time?
Old Jul 29, 2002 | 09:52 AM
Doctor CorteZ's Avatar
test pipe on ?
Old Jul 29, 2002 | 09:56 AM
Willard's Avatar
Default Re: oil burned after event.... (Doctor CorteZ)
test pipe on ?
yup.
Will
-who burns twice as much oil when using a test pipe.
Old Jul 29, 2002 | 10:22 AM
Tommy_Gunns's Avatar
Default Re: oil burned after event.... (Willard)
This one is new to me. What is the reasoning behind this? Increase exhaust flow equals increase oil burnt? What about those with high flow cats, same thing?
Will who burns twice as much oil when using a test pipe.
Old Jul 29, 2002 | 10:24 AM
01PYITR's Avatar
Default Re: oil burned after event.... (SuperTech)
lots of time in VTEC=Lots of oil burnt-
same for me.
Old Jul 29, 2002 | 10:43 AM
Willard's Avatar
Default Re: oil burned after event.... (Tommy_Gunns)
not sure why.... but it does.. the smell =
I guess extra time at 8000+ on track = oil eating anyway... but the lack of back pressure may have something to do with it.
Will
Old Jul 29, 2002 | 11:30 AM
That's why I opted for the high flow cat. I haven't noticed more oil burnt because of it.
-Tommy who can't stand driving behind a vehicle equipped with a test pipe.
Old Jul 29, 2002 | 11:31 AM
Willard's Avatar
yup...
my second highflow cat should be here Thursday.
Old Jul 29, 2002 | 11:42 AM
Second? what happened to your first one?
I have the 94006, clearance was the only problem I have had (which has be fixed).
Old Jul 29, 2002 | 12:12 PM
its on my car , small rattle once in awhile
Old Jul 29, 2002 | 12:20 PM
Tweakmeister's Avatar
get a catchcan
I burn mad oil too
Old Jul 29, 2002 | 12:53 PM
nsxtcjr's Avatar
New User
This is normal. Just check your oil periodically when you're at the track.
BTW...
Mobil (actually, ExxonMobil Corporation) does not make an oil called Syntech. And they don't make any oil in Mobile, Alabama. But Mobil makes a synthetic oil called Mobil 1, and Castrol makes a synthetic oil called Castrol Syntec.
Old Jul 29, 2002 | 01:22 PM
csufweed's Avatar
Default Re: oil burned after event.... (nsxtcjr)
i have no vtec and i burn oil... at 3k miles, i checked my oil before the oil change and i barely had enough to drive the car without damaging it.
Old Jul 29, 2002 | 07:43 PM
Default Re: oil burned after event.... (Tweakmeister)
get a catchcan
I burn mad oil too
what that guy said /\/\
Old Jul 29, 2002 | 09:56 PM
mugenracer's Avatar
I did burn about 1 litre every 1000miles too (72K on engine), thought it might have been bad valve seals but it turned out the oil rings were fairly cooked, so replaced them and every other seal and gasket in the head plus comp rings, now no more burning oil at all!!!
[Modified by mugenracer, 6:57 AM 7/30/2002]
Old Jul 30, 2002 | 12:18 AM
DutchITR1689's Avatar
Sounds normal to me. Keep using that Castrol at the track....
Old Jul 30, 2002 | 01:04 AM
Xia0w0ng's Avatar
Default Re: oil burned after event.... (DutchITR1689)
You drive to hard man...hee hee
Same here too tho....so I think its normal
Old Jul 30, 2002 | 07:50 AM
bus stop's Avatar
get a catchcan
I burn mad oil too
are you saying CatchCan can help in burn oil situation ??
Old Jul 30, 2002 | 10:26 AM
TaboR's Avatar
New User
i do use a oil catch can, and i do run on test pipe
but still it burnt one full quart of oil, not once but twice.
so i think its just normal than....
C-Mugen R, we had a good time on Saturday's Streets of Willow
mrlegoman
Jul 22, 2008 10:31 AM
mrlegoman
Jun 30, 2008 08:27 AM
bigslimdog
42
Mar 27, 2004 03:02 PM
b00sted4dr
Oct 17, 2003 04:35 PM
jond
Nov 27, 2001 08:17 PM
