divided mani divided turbo one wastegate questions
Old Oct 19, 2008 | 12:24 PM
spoolin turbo s's Avatar
Default divided mani divided turbo one wastegate questions
has this been done? if so could someone show some pictures?
i know the problem with this idea and setup is boost creep well what if i was to run no less than 15psi do you think i would have creeping issues?
i wish someone would make a divided t3 other than ATP's with a .78 which is not big enough...............or does someone else make one? if they do i didn't know it
i want to try a twinscroll 35r or a BW roughly the same size as the 35r
Old Oct 19, 2008 | 07:13 PM
Schister66's Avatar
Man U FTW
You need to finish your other thread(s) before getting into this aspect of the project. There are more important questions to be answered here.
To answer this briefly, yes you can do it. All that has to be done is to cut two holes, one on each side of the divided housing and run a Y-pipe to a single 44mm wastegate. I"m sure you could find pics if you looked around...
karmadhi
Mar 8, 2014 11:42 AM
gsrt
Dec 17, 2009 06:18 AM
Speed Infliction
Jul 10, 2006 03:23 PM
ineedhelp
Apr 13, 2004 10:16 AM
dmak
Mar 18, 2003 10:15 PM
