divided mani divided turbo one wastegate questions
has this been done? if so could someone show some pictures?
i know the problem with this idea and setup is boost creep well what if i was to run no less than 15psi do you think i would have creeping issues?
i wish someone would make a divided t3 other than ATP's with a .78 which is not big enough...............or does someone else make one? if they do i didn't know it
i want to try a twinscroll 35r or a BW roughly the same size as the 35r
Man U FTW
You need to finish your other thread(s) before getting into this aspect of the project. There are more important questions to be answered here.
To answer this briefly, yes you can do it. All that has to be done is to cut two holes, one on each side of the divided housing and run a Y-pipe to a single 44mm wastegate. I"m sure you could find pics if you looked around...
