tuning the ecu?
Old Oct 17, 2008 | 08:41 AM
TravisCadello's Avatar
Default tuning the ecu?
How much will it cost to get my ecu tuned and reprogrammed, i just want to raise my rev limiter and get rid of my top speed limiter. its a b15b7 1992 civc sedan. dx. the motors built for higher rpms and all just its running on a stock ecu.
Old Oct 17, 2008 | 08:47 AM
davefromPA's Avatar
Default Re: tuning the ecu? (TravisCadello)
http://www.phearable.net
you ask so many questions!! its good but a search would have yeilded the same results.
Old Oct 17, 2008 | 08:52 AM
turbojdmhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how to use the search button.</TD></TR></TABLE>
Old Oct 17, 2008 | 09:09 AM
creep'n son's Avatar
wow, this is ur third thread your an idiot. SEARCH.
Old Oct 17, 2008 | 09:23 AM
id like to hear how your d15b7 is built for higher RPM's
Old Oct 20, 2008 | 07:54 AM
Default Re: tuning the ecu? (turbojdmhatch)
i just know it can handle it because the guy i got it from just rebuilt it and i was their half the time the block was in his shop. and he wrecked the car later and i got the motor cheap. and its under 2000 miles on it. it has some sort of aftermarket cam and id have to ask him what kinda pistons and **** he ran but i know it wasn't stock ones.
My friend told me he is running a p-028 ecu in his d15b7 instead of the stock p06 and he says its way faster because it thinks the b7 has v-tec and it automaticly dumps more fuel into the motor and advances the timing at a certain rpm. and he said the stock p06 like i have red lines at 7 grand and the p28 ecu goes to 7800.
can i change my ecu out for a d16z6 ecu???
Old Oct 20, 2008 | 09:13 AM
davefromPA's Avatar
can i change my ecu out for a d16z6 ecu???</TD></TR></TABLE>
you can if you want to blow your motor up. i know your young and curious but get it done right please. we are here to help and no one will condone you putting a p-28 on your d15b7.
i have the same motor in my car dude. its not strong and we all know that. i use it for commuting though so 102 hp is more then enough for me. if you want more fuel and advanced timing, put new injectors in and get a tuner to make your car work the correct way so it does not break. there is a reason that motor is redlined lower then the z6.
Old Oct 21, 2008 | 07:38 AM
Default Re: tuning the ecu? (davefromPA)
Any stock honda motor can up to 8100 RPM and then after thats when the stock valvetrain will come apart and drop a valve into the combustion chamber. i know this but my motor is brand new and is built good aftermarket crap. im not looking to rev it higher than 7600rpm. i just want that extra 600 rpm because im on a 4speed auto right now and when i switch gears it has huge *** gears and goes to like 3000rpm from a 7 grand 1st gear to 2nd gear and that kills it. i have a 5speed at the shop but i don't have the time to do it right now.
Old Oct 21, 2008 | 07:51 AM
macson's Avatar
I'm not sure any stock motor can get that high without some issues man. It might not blow today or tomorrow, or even at all, but what's the purpose? You're hardly making any extra power up that high if you are at all.
Old Oct 21, 2008 | 07:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">he says its way faster because it thinks the b7 has v-tec and it automaticly dumps more fuel into the motor and advances the timing at a certain rpm.</TD></TR></TABLE>
your joking
Old Oct 21, 2008 | 07:55 AM
Default Re: tuning the ecu? (macson)
yea, I'm getting my best HP at like 5800rpm BUT that not why i want that extra 600rpm when im in 1st it switch's at 7,000 and then it hits 2nd gear and is at 3500 RPM if i could switch 1st gear at 7600 rpm it would be at 4100rpm which is way closer to my top notch hp. and will help a lot. if i had my 5speed in it i would have 5 small gears and wouldn't be a problem. but i dont i have 4 big *** gears and 1 week *** motor. You understand what I'm trying to do?
Old Oct 21, 2008 | 07:59 AM
EJ8_Enthusiast's Avatar
my god dude... is this normal to do to a civic? I wouldn't go NEAR 7000 rpms id be afraid my car would explode!
Old Oct 21, 2008 | 08:00 AM
Default Re: (EJ8_Enthusiast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">my god dude... is this normal to do to a civic? I wouldn't go NEAR 7000 rpms id be afraid my car would explode! </TD></TR></TABLE>
let him do it and show everyone how much of a retard he is
Old Oct 21, 2008 | 09:00 AM
00b20vtecoupe's Avatar
Default Re: (turbojdmhatch)
dude u honestly sound like an idiot please stop posting everywhere on stupid things. how r u driving anyway didnt u break ur header off ur head on a hole or sumthin mayb its time we put the keys away and relax.
Old Oct 21, 2008 | 11:07 AM
DoWnfall's Avatar
ever try clicking on the other forums for say, engine management?
edit: or realize your 100hp wont go fast even if you bring it to 10000rpm
Old Oct 22, 2008 | 07:10 AM
Retard? Sounds like yall are the damn retards because any Honda motor can do 7 grand all day no problem. I'm guessing you little unexperiental retards should read a little more? dam quirs.
Don't talk **** unless your smart enough to back it up.
Old Oct 22, 2008 | 07:13 AM
Default Re: (TravisCadello)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">Retard? Sounds like yall are the damn retards because any Honda motor can do 7 grand all day no problem. I'm guessing you little unexperiental retards should read a little more? dam quirs.
Don't talk **** unless your smart enough to back it up.</TD></TR></TABLE>
HAHAHAA gtfo
Old Oct 22, 2008 | 07:14 AM
Default Re: (00b20vtecoupe)
Well I assumed this is a site for HELP not BS. so I thought I'd give it a try but turns out half of you are more retards than me. Thanks for nothing *********. and thanks for you who tried and didn't be ***'s.
I'm asking a simple *** question, answear it and leave. don't tell me I'm a dam retard let me do my thing if i wanna take my chances on blowing my motor then let me and just tell me how to get rid of the stock limiter. i paid for the dam motor its no dam problem its a dam single cam and they hold together waaaay better than yalls damn B's.
Old Oct 22, 2008 | 07:18 AM
1. You make about 2 or 3 new posts on the same topic
2. all of your questions could have been answered with the search function
3. learn how to spell
turboblack2door
15
Aug 22, 2008 06:54 AM
Civic138
10
Jun 27, 2007 02:23 AM
NHBP_Civic
Honda Civic (2006 - 2015)
Mar 12, 2007 04:50 PM
o0Jash0o
11
Oct 30, 2006 09:11 AM
P@@RB@Y
Nov 17, 2005 06:23 PM
