no vtec???
Old Oct 16, 2008 | 08:37 PM
FutureCivic's Avatar
Default no vtec???
im running a d16a engine with a manual tranni, and p08 which is a d15b ecu but not getn any vetch.... oh! and its standard harness too...why? am i using the wrong ecu?
Old Oct 16, 2008 | 09:02 PM
Radim's Avatar
Default Re: no vtec??? (FutureCivic)
Does the Solenoid work?
Might be a problem with you running a SOHC ECU on a DOHC Engine, not sure though.
Old Oct 16, 2008 | 09:04 PM
civicmulisha's Avatar
yea we need to know what motor u have is it a d16a6 or a d16z6 or a d16y8 we need to know and what u mean stock harness stock never ment to have v tec
Old Oct 16, 2008 | 09:05 PM
Radim's Avatar
Default Re: (civicmulisha)
I think he meant B16A.
Old Oct 16, 2008 | 09:06 PM
wait u have a b series motor on a single cam ecu is the ecu programmed for v tec
Old Oct 16, 2008 | 10:18 PM
aftermath1312's Avatar
hey bro shouldnt you be using a pr3 or p28 ecu..im not sure they make p08..are you running ob0 or ob1...
Old Oct 17, 2008 | 02:38 AM
UKDMEP3's Avatar
hey man yea the p08 is vtec capable but do u have vtec wired up properly cause im sure u know that the plugs on most of the head look the same and jw is the speed sensor working?
Old Oct 22, 2008 | 12:00 PM
Default Re: (Radim)
the engine block says d16a, my speed sensor is working, the ecu says p08-901 and my harness is obd1
Old Oct 22, 2008 | 12:43 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (FutureCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FutureCivic &raquo;</TD></TR><TR><TD CLASS="quote">the engine block says d16a, my speed sensor is working, the ecu says p08-901 and my harness is obd1 </TD></TR></TABLE> Wait what d16as had vtec?
Have you done a mini me?
Old Oct 22, 2008 | 03:16 PM
alwaystootall's Avatar
Default Re: (***$nyper)
no they did make a straight D16a nothin else after it and its a sohc vtec its some sort of euro engine or something i think my friend has one in his eg i've never seen it either till then
axis11
Dec 17, 2019 02:17 AM
Nicaraguense13
Jan 24, 2017 01:35 PM
Phelps814
Feb 7, 2015 08:05 AM
4gvtec
10
Feb 28, 2002 06:01 PM
