difference between b-series LS tranny and GSR tranny
Old Oct 16, 2008 | 06:52 PM
tacorunner87's Avatar
Default difference between b-series LS tranny and GSR tranny
I have searched on hear and google. really didnt get a solid answer. I have a b18 in my garage that i plan to drop into my car. So what is the benefit of going with gsr over ls transmission
Old Oct 16, 2008 | 06:54 PM
eg_boi's Avatar
Default Re: difference between b-series LS tranny and GSR tranny (tacorunner87)
i believe they both share the same 1st and 2nd gear but on the gsr 3/4/5 and final are shorter. the ls ratios after 2nd gear are all longer then the gsr
someone with more knowledge can chime in
Old Oct 16, 2008 | 06:56 PM
Default Re: difference between b-series LS tranny and GSR tranny (eg_boi)
so longer meaning that on the freeway it will run lower RPM? besicly im useing the car for DD not racing nothing like that. RIght now its a d15 auto and im going b18 manual because the gutless car is driving me nutz
Old Oct 16, 2008 | 06:58 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 &raquo;</TD></TR><TR><TD CLASS="quote">so longer meaning that on the freeway it will run lower RPM?</TD></TR></TABLE>
Exactly.
Old Oct 16, 2008 | 06:59 PM
Default Re: difference between b-series LS tranny and GSR tranny (94EG8)
so if what is true in the second post. im better off with the LS transmission?
Old Oct 16, 2008 | 07:02 PM
eg_boi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 &raquo;</TD></TR><TR><TD CLASS="quote">so longer meaning that on the freeway it will run lower RPM? besicly im useing the car for DD not racing nothing like that. RIght now its a d15 auto and im going b18 manual because the gutless car is driving me nutz</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 &raquo;</TD></TR><TR><TD CLASS="quote">so if what is true in the second post. im better off with the LS transmission?</TD></TR></TABLE>
correct you would want the LS one
Old Oct 16, 2008 | 07:05 PM
naRIPSTA's Avatar
I am my avatar
OR, GSR tranny with a LS 5th gear.
Old Oct 16, 2008 | 07:09 PM
Default Re: (naRIPSTA)
the reason i was asking i found a used gsr for 350 on craigslist and a used ls for 250 on craigslist
Default Re: (tacorunner87)
gsr have LSD or is that just an extra?
Old Oct 16, 2008 | 07:14 PM
iamthefollower's Avatar
The LSD is kind of an extra thing. If u ever want to see if it is LSD though, look through the differential hole and see if the pin is in there, if it is it isn't LSD if it isn't then it is..
Old Oct 16, 2008 | 07:18 PM
Default Re: (iamthefollower)
cool thanks for the help everyone
jo6wo's Avatar
or you could scrap all these trannys and do a true type r tranny. i have one forsale, expensive tho
Old Oct 16, 2008 | 07:27 PM
Default Re: (jo6wo)
no thanks
btw i was just in west chester for 2 weeks with work, just flew home monday
hatch96y7
Jul 9, 2007 03:49 PM
wizzards581
Apr 17, 2007 03:17 PM
tegasaurus
Feb 5, 2007 07:29 PM
Stingray96
Jan 22, 2006 08:23 PM
NathanMorris
Dec 9, 2004 04:41 PM
