difference between b-series LS tranny and GSR tranny
I have searched on hear and google. really didnt get a solid answer. I have a b18 in my garage that i plan to drop into my car. So what is the benefit of going with gsr over ls transmission
Re: difference between b-series LS tranny and GSR tranny (tacorunner87)
i believe they both share the same 1st and 2nd gear but on the gsr 3/4/5 and final are shorter. the ls ratios after 2nd gear are all longer then the gsr
someone with more knowledge can chime in
Re: difference between b-series LS tranny and GSR tranny (eg_boi)
so longer meaning that on the freeway it will run lower RPM? besicly im useing the car for DD not racing nothing like that. RIght now its a d15 auto and im going b18 manual because the gutless car is driving me nutz
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 »</TD></TR><TR><TD CLASS="quote">so longer meaning that on the freeway it will run lower RPM?</TD></TR></TABLE>
Exactly.
Exactly.
Re: difference between b-series LS tranny and GSR tranny (94EG8)
so if what is true in the second post. im better off with the LS transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 »</TD></TR><TR><TD CLASS="quote">so longer meaning that on the freeway it will run lower RPM? besicly im useing the car for DD not racing nothing like that. RIght now its a d15 auto and im going b18 manual because the gutless car is driving me nutz</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacorunner87 »</TD></TR><TR><TD CLASS="quote">so if what is true in the second post. im better off with the LS transmission?</TD></TR></TABLE>
correct you would want the LS one
Re: (tacorunner87)
The LSD is kind of an extra thing. If u ever want to see if it is LSD though, look through the differential hole and see if the pin is in there, if it is it isn't LSD if it isn't then it is..
tegasaurus
02-05-2007 07:29 PM
betwen, check, d15, difference, diffrence, gsr, ios, ls, meaning, powerful, regular, tranny, transmision, transmission, wats
