how to check for bad rings?
Old Oct 15, 2008 | 05:18 PM
cleanej2's Avatar
Default how to check for bad rings?
just recently something went wrong with the motor and i have white smoke coming out of my exhaust. i know it could be a head gasket but someone also told me that it could be a bad ring too...if this is a possibility then i would probably be leaning more towards that just because of the way it sounds when im driving it.. sooo how would i check to see if it is a bad ring without ripping the whole motor apart? TIA
Old Oct 15, 2008 | 05:23 PM
cycopath's Avatar
* B A N N E D *
Default Re: how to check for bad rings? (cleanej2)
Headgasket.
Bad rings you will have blue smoke coming out. (correct me if I'm wrong)
Old Oct 15, 2008 | 05:29 PM
cleanej2's Avatar
Default Re: how to check for bad rings? (cycopath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycopath &raquo;</TD></TR><TR><TD CLASS="quote">Headgasket.
Bad rings you will have blue smoke coming out. (correct me if I'm wrong)</TD></TR></TABLE>
..ok well if its not rings then is there any thing else besides a headgasket that could cause antifreeze to get into the motor?
Old Oct 15, 2008 | 05:48 PM
batallic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 &raquo;</TD></TR><TR><TD CLASS="quote">
..ok well if its not rings then is there any thing else besides a headgasket that could cause antifreeze to get into the motor?</TD></TR></TABLE>
nope bad HG
Old Oct 15, 2008 | 05:51 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 &raquo;</TD></TR><TR><TD CLASS="quote">..ok well if its not rings then is there any thing else besides a headgasket that could cause antifreeze to get into the motor?</TD></TR></TABLE>
its either a blown head gasket, cracked head, or cracked block. My moneys on the headgasket.
Old Oct 15, 2008 | 05:52 PM
cleanej2's Avatar
Default Re: how to check for bad rings? (batallic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic &raquo;</TD></TR><TR><TD CLASS="quote">
nope bad HG</TD></TR></TABLE>
ok thanks.. is it normal for the motor to make a weird sound with a bad hg though?
Old Oct 15, 2008 | 06:02 PM
cycopath's Avatar
* B A N N E D *
You want to replace that HG ASAP!!! If you keep driving like this you can warp the head or block and it will never seal correct again.
Old Oct 15, 2008 | 06:08 PM
cleanej2's Avatar
im not driving it i only took it out to try to diagnose the problem..but any ideas on what the noise could be?
Old Oct 15, 2008 | 06:15 PM
cleanej2's Avatar
oh and what is everybody's thoughts on a cometic vs oem gasket.. i might be going turbo this summer so i figured id do it while its out now
Old Oct 15, 2008 | 06:22 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 &raquo;</TD></TR><TR><TD CLASS="quote">oh and what is everybody's thoughts on a cometic vs oem gasket.. i might be going turbo this summer so i figured id do it while its out now</TD></TR></TABLE>
3 layer steel. I'm assuming you have a D15B7? I really wouldn't recomend turboing that after its blown a headgasket, its hard enough trying to keep them from blowing a second time naturally aspirated.
Old Oct 15, 2008 | 06:37 PM
cleanej2's Avatar
Default Re: how to check for bad rings? (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
3 layer steel. I'm assuming you have a D15B7? I really wouldn't recomend turboing that after its blown a headgasket, its hard enough trying to keep them from blowing a second time naturally aspirated.</TD></TR></TABLE>
forgot to mention the b7 was just swapped out for a b16a a couple months ago
Old Oct 15, 2008 | 07:50 PM
cleanej2's Avatar
no one knows what that sound could be??
Old Oct 15, 2008 | 08:03 PM
jasony0630's Avatar
76.26.106.124
well if it's white smoke, it CANNOT be your rings.
If it were your rings, you'd be burning oil. Hence blue smoke.
It sounds more like a headgasket.
Unless it sounds like a scooby....mine did when it cracked a sleeve. White smoke everywhere!
Old Oct 15, 2008 | 08:20 PM
cleanej2's Avatar
Default Re: (jasony0630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 &raquo;</TD></TR><TR><TD CLASS="quote">well if it's white smoke, it CANNOT be your rings.
Unless it sounds like a scooby....mine did when it cracked a sleeve. White smoke everywhere!</TD></TR></TABLE>
there's really not that much smoke.. but something like a grinding/scraping sound when i give it some gas.. not so much when driving normally
Old Oct 15, 2008 | 11:24 PM
jasony0630's Avatar
76.26.106.124
any knocking??
try to do a leakdown test/compression test.
Old Oct 16, 2008 | 12:38 AM
tunerkid7's Avatar
ya i would compression check it and replace your headgasket, those are the exact things that were happening with mine before i swapped it out
LaOXXKIDD
Aug 15, 2009 12:05 PM
iluvmycivichatch
Jun 16, 2008 11:40 PM
tuner_3
Feb 21, 2005 08:46 AM
1SickHb
17
Mar 8, 2004 01:43 AM
slow02ss camaro
Aug 4, 2002 05:00 AM
