Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Around Portland OR Shops?
Old Oct 15, 2008 | 03:38 PM
DA808CHOPSHOP's Avatar
Default Around Portland OR Shops?
New to Portland, looking for a badass machine shop that can (hot tank, Bore, Hone, B18's etc). Also looking for a shop or the same shop that install motors, work with ECU's, and can tune.
Thanks
Old Oct 16, 2008 | 09:19 AM
RRev Tim's Avatar
Default Re: Around Portland OR Shops? (DA808CHOPSHOP)
Tabor's Automotive in Vacnouver WA is a very good machine shop. They build all our race engines. We can help you with anything else you need, just let me know.
Old Oct 16, 2008 | 10:52 AM
jime64871's Avatar
Default Re: Around Portland OR Shops? (RRev Tim)
Tabors for sure....
and RRev, can't forget
360 Imports up in Vancouver,WA
Old Oct 16, 2008 | 05:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RRev Tim &raquo;</TD></TR><TR><TD CLASS="quote">Tabor's Automotive in Vacnouver WA is a very good machine shop. They build all our race engines. We can help you with anything else you need, just let me know.
Ok RRev Tim so after Tabor's takes my head and block apart, ports, polishes, hot tanks, hones, mills my motor, how much would you charge to put it all back together and maybe back in my car....if I can afford it?
Thanks again for the info!
Old Oct 17, 2008 | 02:58 PM
Evs-One's Avatar
Solbros Owns Me
to Tabor's
Old Oct 17, 2008 | 04:34 PM
Default Re: Around Portland OR Shops? (Evs-One)
Hey Evs-One, correct me if I am wrong but you are Evan and you run 360 right? If so I heard alot of good stuff about you and your shop. Could you give me an estimate of how much you think it would cost to get my motor taken apart, hot tanked, port, polished, milled at Tabors?
What kind of services could you offer me after my motor comes back from Tabors? Could you put my motor back together, install, and tune? If so how much am I looking at?
Thanks
Old Oct 24, 2008 | 03:18 PM
JDMB16DA6's Avatar
^^ Where you from cuz? 808?
Check out PSI over in Hillsboro. They do solid work. There's an AEM expert there as well.
-Brian (808DA6)
Old Oct 24, 2008 | 04:26 PM
RRev Tim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA808CHOPSHOP &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks again for the info! </TD></TR></TABLE>
Give me a call when you get a chance and we can discuss. I am about to have a deal on labor coming up next month. Thanks Tim (503) 289-4020.
grumblemarc
Southeast
Aug 29, 2014 03:55 AM
kpowerdhatch
Mid-Atlantic
Oct 29, 2007 08:15 PM
Evil_Pull
Oct 22, 2004 10:52 AM
unknown2
May 18, 2004 01:50 PM
AznInvasion
Mar 9, 2004 06:50 PM
