B18/B20 bore
Old Oct 11, 2008 | 04:41 PM
Ct4754's Avatar
Default B18/B20 bore
After boreing out my block from 81mm to 84mm is it still going to be reliable enough to run Hi boost when desired and not have to worry about the block crackin.. given that i have a decent setup.. resleeve, pistons..ect...??
Old Oct 11, 2008 | 05:11 PM
thabao's Avatar
Default Re: B18/B20 bore (Ct4754)
if you bored out a b18a/b block to 2.0. hell yeah it's going to be weak. i would really sleeve it if you going to boost it. depending on how many pounds though, if your going for about 8-12 you might be safe with out a sleeve.
Old Oct 11, 2008 | 06:24 PM
Ls_Turboteg's Avatar
Default Re: B18/B20 bore (thabao)
agreed
RACEPAK
Dec 12, 2005 01:13 PM
v.i.gsr
Dec 16, 2004 01:15 PM
majek
Oct 14, 2004 02:49 PM
countryboy
Sep 15, 2004 07:06 PM
TypeR0149
Aug 22, 2001 12:32 AM
