VSS issue..
Old Oct 11, 2008 | 03:40 PM
Vtec Civic 93's Avatar
Default VSS issue..
Alright well i swapped a new transmission into my car and i was told it was a y7 tranny, and speedometer nor odometer are working so i assumed right away it was the VSS. Also a check engine light comes on during de-acceleration, which is caused by the VSS.
I'm pretty sure my VSS is for an automatic trans, because it has a circular thing o the top of the VSS like the Auto ones do, but when i tried a manual one my speedo still jumped around or dint work, Any suggestions???
Modified by Vtec Civic 93 at 3:02 PM 10/15/2008
Modified by Vtec Civic 93 at 3:13 PM 10/15/2008
Modified by Vtec Civic 93 at 3:30 PM 10/15/2008
Old Oct 11, 2008 | 08:38 PM
bump
Old Oct 15, 2008 | 11:03 AM
Default Re: (Vtec Civic 93)
Anyone please help!
Old Oct 15, 2008 | 11:10 AM
singleslamit's Avatar
did you transfer the whole unit or just the top
Old Oct 15, 2008 | 11:12 AM
97ek-t's Avatar
Default Re: (singleslamit)
should just go right in.. all the hole size is the same just defferent type sensors
Old Oct 15, 2008 | 11:14 AM
Default Re: (97ek-t)
With 96+ VSS u cant take the sensor apart from the shaft, so i tried a complete other VSS..
I did find out my VSS is for an automatic tranny, but even when i tried the manual VSS it still didn't work.
Old Oct 15, 2008 | 01:12 PM
503_EF9's Avatar
sounds like a bad ground to me, make sure all the wiring is good and the plug is clean and check the vss for water pooled up in it tends to happen when working on things like that.
Old Oct 15, 2008 | 01:22 PM
I'm not sure which ground it would be, the one from the body to the tranny is hooked up. I didn't see any fluids in the vss. It also makes me thing the plug from the harness is wack, my previous tranny did the same thing sometimes. Idk what to do..
Old Oct 15, 2008 | 06:56 PM
nemisish20's Avatar
Wheres my titleeeee!
make sure the gear on the end is the one from the right tranny.. i had the same issue .. the gear isnt always the same size as most of the D series!
civic4life8045
Aug 6, 2011 04:41 AM
VtecCivic93
Mar 25, 2008 07:38 PM
Freshazzburu
Oct 17, 2004 10:12 PM
miataguy
Jul 17, 2003 02:25 PM
