wat is this?
Old Oct 11, 2008 | 02:57 PM
801ef's Avatar
Default wat is this?
so me and my friend were bleeding his clutch cuz his resvoir is leakin somewhere and it ran out of fluid so it had air bubbles,, while lookin for the leak we came across this and jus were curious wat it is.
Old Oct 11, 2008 | 02:59 PM
801ef's Avatar
Default Re: wat is this? (801ef)
it looks like a hose or somethin goes on it but i stuck a screw driver in it and theres somethin blockin it.
Old Oct 11, 2008 | 03:08 PM
pprowler6's Avatar
its the breather for the transmission. a little rubber cap is supposed to be on it but it really doesnt matter mine is open too
Old Oct 11, 2008 | 05:27 PM
801ef's Avatar
Default Re: wat is this? (pprowler6)
oh sweet thanks
Old Oct 12, 2008 | 04:53 AM
flyrod's Avatar
I would at least roll up a piece of paper towel and stuff it in there. Any dirt or grit you get in there goes through your gears and bearings. And since there's no filter on the transmission oil, it goes through the gears over and over.
Old Oct 12, 2008 | 07:42 AM
Finest's Avatar
Default Re: wat is this? (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">I would at least roll up a piece of paper towel and stuff it in there. Any dirt or grit you get in there goes through your gears and bearings. And since there's no filter on the transmission oil, it goes through the gears over and over.
A rolled up piece of paper towel is just as bad as dirt when it makes it way down into the transmission.
Old Oct 12, 2008 | 09:56 AM
TheWalrus's Avatar
Default Re: wat is this? (Finest)
wrap a piece of screen around it and ziptie...just dont block it off, the pressure in the trans will push oil out instead of air
Old Oct 12, 2008 | 10:24 AM
flyrod's Avatar
Well, don't stuff it into the transmission. Just plug the vent with it, and leave enough hanging out so you can remove the plug to change the oil. It will still let air through but will keep the dirt out. Mine's been in place for the last 50k miles.
ramboPandA
Apr 20, 2015 06:01 AM
hardboiled
Honda Civic (2001 - 2005)
14
Nov 25, 2010 09:19 AM
95greenlude
May 17, 2009 11:40 AM
wesvailco
Honda Motorcycles
27
May 16, 2008 06:06 PM
99shRIGGS
Jan 7, 2005 08:10 AM
