NEED HELP WITH THESE TWO HOSES!!!
I pulled off my turbo and I have these two rubber hoses that come from under the
fuel rail and lead to this plastic unit thing lol. I'm trying to figure if that is for my
turbo or if it's stock and they mounted it in another spot. Let me know what I need to do to clean this shiznit up. Thanks!
so just pull the hoses off at the end by the fuel rail? Won't that give me a vacuum leak?
What about the sensor like piece? IS ALL of that aftermarket or what?
I have been wondering what I can do with these hoses also!!! Someone please help this guy (and myself). I would like to just get rid of them because they are ugly. I am a minimalist!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedEBP »</TD></TR><TR><TD CLASS="quote">so just pull the hoses off at the end by the fuel rail? Won't that give me a vacuum leak?
What about the sensor like piece? IS ALL of that aftermarket or what?</TD></TR></TABLE>
Remove the secondary air pump. You'll throw a CEL if you're still using the OEM ECU.
Ohhh, so you just took that right out then huh? No leaks no nothin'? Really appreciate
the help man
! Trying to get my car free of issues for when I sell it
the help man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedEBP »</TD></TR><TR><TD CLASS="quote">oh and that plug i nthe second picture of mine... was that used for the turbo?</TD></TR></TABLE>
No, has nothing to do with the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedEBP »</TD></TR><TR><TD CLASS="quote">Ohhh, so you just took that right out then huh? No leaks no nothin'? Really appreciate
the help man
! Trying to get my car free of issues for when I sell it</TD></TR></TABLE>
Keep in mind. If you're using an OEM ECU (which I hope you're not since you're turbo), it will throw a CEL if you remove those hoses and the secondary air pump. The secondary air pump is under your drivers side headlight.
the help man
! Trying to get my car free of issues for when I sell it</TD></TR></TABLE>Keep in mind. If you're using an OEM ECU (which I hope you're not since you're turbo), it will throw a CEL if you remove those hoses and the secondary air pump. The secondary air pump is under your drivers side headlight.
Oh I think that is already removed. I get a code that if I remember correctly says... Seconday Air Injection. I'm just trying to figure out still what that black box looking thing is. I am N/A now... the turbo was removed and I am now running on my stock ECU.
So that plug that is running to that other black box that is mounted on the frame, that stays since I am N/A right? I guess I am confused cause these look like factory plugs (2 of them) that lead to that black piece that I am holding in my hand in the last pic. Doesn't look like those should be removed...
Do not remove the thing you are holding in the last picture. I don't know exactly what it is, but it has to do with the secondary air pump. One of the two hoses that you removed (the ones that come from under the fuel rail) connects to that black box that you're holding. You see the little thing that's protruding out next to the plug. The hose goes there.
If you're not turbo charged anymore, you should reinstall the secondary air pump as it's needed to pass emissions and to eliminate that CEL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote">Do not remove the thing you are holding in the last picture. I don't know exactly what it is, but it has to do with the secondary air pump. One of the two hoses that you removed (the ones that come from under the fuel rail) connects to that black box that you're holding. You see the little thing that's protruding out next to the plug. The hose goes there.
If you're not turbo charged anymore, you should reinstall the secondary air pump as it's needed to pass emissions and to eliminate that CEL. </TD></TR></TABLE>
Yea I got two protuding black pieces where the hose would go over and one hose from under the fuel rail leads to one, and another hose leads into the other hole that is coming from the black plastic box looking thing in the second to last pic. I have 2 hoses coming out from under the fuel rail.
You also tell me to keep that the black plastic piece, in the second to last pic... the only thing is that one of the lines that are under the fuel rail lead to that box. Then from that box leads into one of the holes on the plug in my last pic. I understand to remove the metal rails that are under the fuel rail after i took a closer look at your pictures, but I would like to know what that black box is, and wher it is on YOUR car or where the factory location is. I guess its just frusturating cause I have been checking out other S's and don't see lines where I have lines/hoses and its kind of pissing me off lol. Oh, and is the location for my secondary air pump right behind my front bumper on the passanger side? Thanks for all the help bro
If I remember correctly, you can find the complete vacuum routing diagram in the honda servioce manual for your S2000. look at spoonhonda.com They have your manual. Good luck!!
V-SPEC 1
Jun 30, 2008 11:38 PM
EK_99_BOI
Dec 23, 2006 07:11 PM
rice a roni
Mar 27, 2006 07:26 AM
. Any one else???
