Hard Idling when stopped?
Old Oct 10, 2008 | 01:57 PM
NathanAZ's Avatar
Default Hard Idling when stopped?
My car Idles pretty hard when i'm at a stop now. More heavily during the day not as bad at night. Typical honda problem but anyone know how to fix/ help from it doing that?
Thanks Guys.
Old Oct 10, 2008 | 02:18 PM
white4doorsi's Avatar
what year car what motor. Exactly what are you idling at when stopped.
Old Oct 10, 2008 | 02:27 PM
BlackoutVTi's Avatar
Default Re: (white4doorsi)
Yeah, I'm having some idle problems too. Is it really low and rough?
For my problem I was thinking it was an IACV clog, but I took it off this morning and it was clean. Anywho, our situation may have different causes. Check out the IACV and see if the screen in the gasket is gunked up. If it is, hit it with some Brake Parts cleaner until it's clean and see if your idle improves.
note: Allow plenty of time for the solution to dry before reinstalling or starting the car.
Old Oct 10, 2008 | 03:43 PM
Former User's Avatar
Default Re: Hard Idling when stopped? (NathanAZ)
Is the CEL ON?
-Try bleeding the cooling system of trapped air and cleaning the fast idle valve if you have one.
-Check for intake air and vacuum leaks.
Old Oct 11, 2008 | 02:38 PM
NathanAZ's Avatar
Default Re: (BlackoutVTi)
1992 Hatchback DX b16A
yeah i guess i'll try cleaning that out see if it helps, if not idk.
Old Oct 11, 2008 | 04:45 PM
Default Re: (NathanAZ)
Yeah, try cleaning both the IACV and the FITV.
jdmdseries
Jan 23, 2008 05:52 PM
the.hamburglar
May 10, 2007 08:46 PM
Al-sonic
Jan 14, 2007 03:56 PM
cyang08
Apr 13, 2006 10:57 PM
hondachris1994
Feb 20, 2006 07:14 PM
