D16Z6 Head on D16Y7 Block
Old Oct 9, 2008 | 07:37 AM
jewpont's Avatar
Default D16Z6 Head on D16Y7 Block
Today i bought a complete D16Z6 head and i will be doing my mini me very soon on my D16Y7(98 civic) and i just wanted to get everything straight. Ive made a list of everything i think i need and i would like to know if i need anything else before i start. Thanks
D16Z6 head
Y8 manifold
Y8 tb cable
LS Throttle body
Tb thermal gasket
IM thermal gasket
Y8 head gasket
Y7/Z6 arp head studs
Valve cover gasket set
dizzy gasket
OBD2-OBD1 jumper
P28 ecu
misc hoses
Z6 timing belt
Y7 fuel rail/injectors
What else do i need to do to change to OBD1?
Modified by jewpont at 11:59 AM 10/9/2008
Old Oct 9, 2008 | 07:56 AM
CivicSpoon's Avatar
For the head bolts/studs, you need 9 for the Y7 block and 1 for the Z6. The 1 for the Z6 goes by the vtec solenoid. Otherwise the head won't seal properly to the block.
You're going to need to do something about the distributor. Using the Z6 distributor and either rewiring the engine harness' plug, or getting a distributor adapter harness.
Old Oct 9, 2008 | 07:58 AM
jewpont's Avatar
i have the right studs already and i have 2 dizzys, 1 dizzy with an adapter and my Y7 dizzy.
Old Oct 9, 2008 | 11:28 AM
jewpont's Avatar
bump
Old Oct 10, 2008 | 10:28 AM
jewpont's Avatar
do i need a Z^ crank pulley?
Old Oct 10, 2008 | 10:49 AM
blkegcoupe's Avatar
From: ....................................................................................................
sorry to hijack the thread but whats the hp difference in the ls throttle body? did some searching but only came up in 1 result that didn't answer my question.
Old Oct 10, 2008 | 10:57 AM
TravisCadello's Avatar
Default Re: D16Z6 Head on D16Y7 Block (jewpont)
I like this. I planed on doing this on my B7. let me know if all the work pays off with more power or is it a waste of time.
Old Oct 10, 2008 | 10:59 AM
jewpont's Avatar
i have no idea, i just have one laying around thats why im using it. i think an LS tb is 58mm
Old Oct 10, 2008 | 05:04 PM
jewpont's Avatar
I was told that I need a z6 crank pulley for correct timing, is this true?
Old Oct 11, 2008 | 01:26 PM
jewpont's Avatar
bump
Old Oct 12, 2008 | 03:49 PM
jewpont's Avatar
I guess that's everything!
hoya_10fintec
25
May 26, 2020 08:40 AM
MrChrisDurban
Oct 7, 2013 11:36 AM
krysted9354
Mar 23, 2009 07:19 PM
PYITR821
Dec 6, 2005 08:27 PM
rspectuning85
Jan 6, 2005 06:54 AM
