B16a sir II into crx si injector resistor box necesary?
Old Oct 7, 2008 | 04:52 PM
catfishracer4748's Avatar
Default B16a sir II into crx si injector resistor box necesary?
I have a b16a sirII going into my crx si. It has a p30 ecu and I sent the harnesses to rywire and had them converted to work for my car and engine combo, also they sent an obd0-obd1 ecu jumper. My question is do I need to do anything as far as with the injector resistor box? I have read something about having to remove it. Thanks for the help.
Old Oct 7, 2008 | 05:57 PM
Outsane's Avatar
depends on what injecters you run..
If you run your old injectors then yes you need a resistor box..
if you run OBD1 injectors then no resistor box..
thats my understanding..
Old Oct 7, 2008 | 06:09 PM
18.lturbo's Avatar
Default Re: B16a sir II into crx si injector resistor box necesary? (catfishracer4748)
COOL
Old Oct 7, 2008 | 07:04 PM
I am just going to run the injectors that came with the engine. By the way my crx is a 1991.
Old Oct 7, 2008 | 07:14 PM
D16SiHatch's Avatar
k well since you're going to run the obd1 injectors just remove the resistor box and solder the 5 wires that go to it together (4 yellow, 1 red).
Old Oct 7, 2008 | 07:34 PM
Is this the resistor box. Im guessing that all I have to do is just not plug it in. The rywire harness doesn't look like it has a plug that will fit it anyways.
Old Oct 7, 2008 | 07:38 PM
It has 4 black and one red. no yellows. And as far as solder them all together could you elaborate a little bit Thanks!
Old Oct 7, 2008 | 07:39 PM
Is it possible rywire just bypassed it for me?
Old Oct 7, 2008 | 08:07 PM
D16SiHatch's Avatar
i lied its 4 red/black, 1 yellow/black. i couldnt recall so i just went out to check my car. yes i realize the colors on the resistor box itself are not those colors however the ones on the engine harness are.
it is possible they did this for you. i belive they use a plug which goes into the male green connector on the harness side which effectively connects all those 5 wires together. if they did not do this then you will need to solder these 5 wires together. and by that i mean tie all of those wires together.
Old Oct 8, 2008 | 05:39 PM
Default Re: B16a sir II into crx si injector resistor box necesary? (D16SiHatch)
D16SiHatch
you are exactly right. I looked at the rywire harness and they inserted a plug that connects all the wires together. Thanks for the great info.
Old Oct 8, 2008 | 09:02 PM
HOODLOVER's Avatar
i just plucked that plug off the engine harness that came with the motor
Old Oct 9, 2008 | 04:17 AM
CRX Toad's Avatar
Please keep all these together...thanks
https://honda-tech.com/zerothread/2404848
Old Oct 12, 2008 | 04:47 PM
the cluster converts that input from the cable into an electric output that is sent back to the ecu That is exactly the info I needed. Thanks!!!!!!!!!
schock3
Aug 25, 2009 12:37 PM
2ndGenREX
Jan 26, 2007 10:12 AM
SupraRXZ
Jan 31, 2006 09:07 PM
BoostBoi
Nov 13, 2004 11:50 PM
redboost10
Oct 23, 2003 03:35 PM
