turbo crx wont start with 750 cc injectors
Old Oct 7, 2008 | 01:51 PM
redflaredcrx90's Avatar
Default turbo crx wont start with 750 cc injectors
i have an turbo b16 and i got a base map from xecrone in ny from my set up. the injector praying out to much fuel at start up. when i un plug the pluse injector box it runs for a few sec and shuts off. this motor hasnt be ran yet. so any ideas would be helpful its a 90 crxsi converted to obd 1
Old Oct 7, 2008 | 02:46 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: turbo crx wont start with 750 cc injectors (redflaredcrx90)
new map...i've had basemaps made and i had to remake them becuase it still didnt crank.
Old Oct 7, 2008 | 02:57 PM
SovXietday's Avatar
Default Re: turbo crx wont start with 750 cc injectors (HybridcivicLS-T)
Is this a brand new motor, fresh build, 0 miles on the rings?
If so, tow it to your tuner and let them start it. The first few running minutes of a fresh engine are very important, you do not want to wash out the rings trying to make it run and drive on a basemap.
Old Oct 7, 2008 | 03:02 PM
Garage 808 Hatch's Avatar
best thing would be to put stock 240cc injectors in it and start it with a stock ecu, to get a few heat cycles in it. thats how i do it when i do a new motor combo
Old Oct 7, 2008 | 04:26 PM
i think its getting way to much fuel so ill change out the oil and and ecu and put in a stock ecu an injectors
Old Mar 20, 2010 | 10:45 AM
1qukcb7's Avatar
Either that or with ur standalone tell it ur runnin smaller injectors like 550 or something, thats what i did to get it running then i went through the fuel map accordingly, then switched it back to 750...just a thought
Old Mar 20, 2010 | 10:52 AM
q16racer's Avatar
tuning....
________
Easy vape digital
Old Mar 21, 2010 | 12:41 PM
sabrosa489's Avatar
key world your engine is getting toooo much fuel tow to tuner or get him to make a house call to bring your injectors down to stock level just to get to start up and break in the engine or like garage 808 hatch said put the stocks ones back on for the break in. One that is done tune it, tune it, tune it!!!! You said you got a base map from a tunner did you told him what injector you were using before he made you the base map. or you just ask for a base map
Old Mar 21, 2010 | 12:46 PM
Jaker's Avatar
No tuner worth his salt would ever burn you a basemap without knowing some details about your build, including what size injectors you are using.
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
dritan
Mar 20, 2011 01:18 PM
418whpturboD
May 31, 2008 09:04 PM
Flexin5
Jun 5, 2007 02:50 PM
civicjdmb16a
Nov 25, 2005 08:02 AM
