B18A1 question
Old Oct 7, 2008 | 01:20 PM
Bozo_JDM's Avatar
Default B18A1 question
does anyone know if the gsr head will fit on a B18A1 block??
Old Oct 7, 2008 | 02:10 PM
tunerkid7's Avatar
Default Re: B18A1 question (Bozo_JDM)
yes
Old Oct 8, 2008 | 11:28 AM
Bozo_JDM's Avatar
thank you
Old Oct 8, 2008 | 01:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Bozo_JDM)
search lsvtec it's not just a bolt on affair.
Old Oct 8, 2008 | 01:19 PM
teg_95's Avatar
Default Re: (***$nyper)
you have to put a little time and effort in doin a ls/v build.
Old Oct 9, 2008 | 03:04 PM
Bozo_JDM's Avatar
will the b series axels fit the si hubs that i currently have on the car
Old Oct 9, 2008 | 04:09 PM
teg_95's Avatar
i read that you have to resurface the head and the block. not sure if that is required. i also read that it is highly recommended to use arp head studs. some kinda oil feed line or something (dont quote me on that) but yea. just do your research and you be alright
Old Oct 9, 2008 | 04:15 PM
knightsef-eg's Avatar
i just finished my ls vtec.... you dont have to re surface... but its recommended
buy a ls vtec kit from eagle ( you can get them on ebay )
tap the head and put the plug in so you dont have oil pissing every where..
use arp or gsr head studs...
new water pump and oil pump is recommended.... ..and please dont rev the car past 7800 rpms casue it cant take it ( unless you build it for that )..
( forgot make sure u get the vtec dowel conversions )
Old Oct 9, 2008 | 04:39 PM
teg_95's Avatar
Default Re: B18A1 question (knightsef-eg)
what kinda head did you end up using
Old Oct 9, 2008 | 04:57 PM
Default Re: B18A1 question (teg_95)
b16a1 jdm spec.. made 181 hp tuned with chrome... skunk2 pro series intake manifold and 68m throttle body aswell...
i chose to go with arp head studs
gsr timing belt.gsr water pump type-r water pump and the golden eagle ls-vtec oil supply kit..
i put all brand new (oem) valves springs and retainers...
Old Oct 9, 2008 | 04:58 PM
teg_95's Avatar
seems pretty stout. whats it in
Old Oct 9, 2008 | 04:59 PM
1991 civic si ... all new rockers doors fenders bumpers and quater panels...
went with a completly oem look no ricey head lights or tails...
Old Oct 9, 2008 | 05:02 PM
Old Oct 9, 2008 | 05:35 PM
teg_95's Avatar
word
B16Civic93
Dec 27, 2004 04:20 AM
M.K.C.
Nov 21, 2003 06:29 AM
RSZero1
Nov 19, 2002 06:18 PM
