Need more power
Old Oct 6, 2008 | 10:39 PM
niceprelude's Avatar
Default Need more power
I recently had a 92 dx 5sp,it's very slow on the first gear and people behind me get pretty unhappy.How to make it go faster.
Old Oct 6, 2008 | 10:52 PM
Davus's Avatar
Default Re: Need more power (niceprelude)
You could swap your transmission for an "EX" model transmission, shorter gearing to get you through the powerband quicker (faster acceleration). You could also go through adding a VTEC head (or a VTEC motor altogether) to get more engine power, but that'll only apply in the high end (which the shorter gear EX transmission would help with too).
An "EX" transmission is about $300 used it seems, and adding a VTEC head shouldn't run you over $200 unless you do a rebuild altogether.
Short of that, you could also run a 40 'shot' of nitrous oxide to help get you through morning traffic.
Overall, you'll probably end up spending a couple of hundred dollars and getting some mechanical experience. If these seem like unfeasable ideas, I'm sure someone else will chime in with something else. (In before "TAKE OUT BACK SEAT".)
Old Oct 7, 2008 | 11:16 AM
civicjoe's Avatar
Default Re: Need more power (Davus)
B18 swap
Old Oct 7, 2008 | 07:45 PM
that is big job,why not just add air intake and big muffler and take out back seat
Old Oct 7, 2008 | 07:52 PM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niceprelude &raquo;</TD></TR><TR><TD CLASS="quote">that is big job,why not just add air intake and big muffler and take out back seat</TD></TR></TABLE>
are you serious?? an air intake and so called big muffler wont do ****. the big muffler will make it worse most likely. and taking out the rear seats will look like hell and wont help alot. your best bet is a tranny swap or a full motor swap or turbo.
Old Oct 7, 2008 | 07:54 PM
mistik_DC4's Avatar
Don't get big muffler. Intake is fine. Headers. Piping (2 1/4 inch). It'll give your car better air flow. High flow cat or gut out your cat. But then on the other hand, this is a reason for u do go a lil bigger. B18 swap???
Old Oct 7, 2008 | 10:28 PM
civicjoe's Avatar
Default Re: Need more power (mistik_DC4)
I still think a B18 would be the optimum choice, but it is a lot of labor and $.
Putting on a "bigger" muffler will probably cut down on back pressure and give you less torque in the low rpms. I would do cold air for sure, then see what you think from there.
xproductionz
Honda Civic (2001 - 2005)
74
Mar 12, 2016 11:07 AM
DSMAddicted
Jan 31, 2015 04:11 AM
ndhs1966
May 4, 2006 01:36 AM
XMarkGuerillaX
Feb 17, 2003 09:17 AM
quikrpm'z
10
Dec 28, 2001 03:57 AM
