Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DIY: DX/LX head swap to EX VTEC
Old 05-14-2006, 06:11 PM
xproductionz's Avatar
Default DIY - DX/LX head swap to EX VTEC
dang.. took us about 4 hours but we finally got it done... dont trust what everyone else says u need.. u dont need the ECU from an EX to convert over.. heres what u will need if you want to avoid getting an ECU from an EX and reflashing ur key:
EX vtec head with solenoid
ex head gasket
and a vafc2
basically if you never have done a head swap before i highly suggest u take it to a shop to do it. we ran into i hiccup after completion cause i had some air bubbles in the coolant but we took care of that in about 10 minutes.. make sure u disconnect the battery before doing the the vafc install
and heres a picture of the cover taken off
the dx head looks like when its off
heres a picture of the ex head.. notice the hanging blue wire.. thats the vtec wire and solenoid...
heres the vafc2 controller.. this is the only way to bypass getting an ECU from an EX and getting your key reflashed
now heres the trick to wiring your ecu.. solder everything and no crimping.. i got a gas powered one so i dont have to worry about running extension cords
now while wiring the vafc2...
first tape off or cap the blue VTM wire cause u will not be using that... also tape off or cap the purple VTEC wire cause u will not be using that either (the DX/LX does not come with a VTEC solenoid signal from the ECU).... also tape the orange wire cause there is no VTC cam signal.. and for other people that are also running the VAFC2 on there EX's we do have a TDC wire on our cars... it would be on pin 26 on the first harness to the left... then follow the installation instructions according to the vafc2 manual using diagram H7-a and dont worry about the other DIY mentioned in another topic thats says to buy a diode.. dont need it... now all u gotta do is finish up ur head install.. as soon as thats done.. remember that blue wire hanging from the EX head.. well cut off the clip
and hard wire it (see the light green wire) from the engine bay into the car next to the ECU... then solder that wire to the pink wire from the vafc... almost there
clean up all ur wires and finish up anything under the hood... fill back ur oil.... add more antifreeze..and now ur car looks pretty much the same when u first started..
haha with the exception of the vtec solenoid and wire.. PLEASE NOTE that if u have had a DX intake then the place where it mounts has to be moved cause that bracket where it used to mount is now replaced with the vtec solenoid..
do the start up proceedures according to what the manual says for the vafc before starting the car... now as for me when i was done.. it took a few minutes before the car actually started... once it finally ran it idled pretty bad and fluctuated... then after a good 2 or 3 minutes the car ran perfectly fine.. my friend says the ecu is just adjusting to the new things we put on there... drove it around for an hour and set my vafc to kick the vtec from
Lo-->Hi at 4700
Hi-->Lo at 4000
just basic settings to get me started but its not even tuned yet and can feel the car pulling alot more when the vtec kicks in
hope this helps
-Mike
Old 05-14-2006, 07:09 PM
brjhnson's Avatar
Default Re: DIY - DX/LX head swap to EX VTEC (xproductionz)
Wow i was asking around about doing this because I really want to. How much did you pay for every thing and how much do you think it would cost to get it done at a shop. also were did you buy everything from
Old 05-14-2006, 07:13 PM
theciv's Avatar
Default Re: DIY - DX/LX head swap to EX VTEC (brjhnson)
you can get the head and **** at a junkyard from an es1 or an em2 i believe.
then jus by the vafc controller
Old 05-14-2006, 08:52 PM
well.. you have to use the em2... i got the head from a junkyard for $200 and had the head milled before i put it on to rasie compression.. gasket i think was like 30-40... its been a while forgot how much it was.. and the vafc2 was $200.. labor was done myself since we did it at the shop so i cant really tell you how much a shop charges.. call around cause shops differ in price from place to place and state to state
Old 05-14-2006, 09:06 PM
theciv's Avatar
Default Re: (xproductionz)
you could do it yourself though right?
can't be that hard?
pretty much bolts?
Old 05-14-2006, 09:08 PM
well... key things to worry about is..
making sure that everything stays TOP DEAD CENTER while doing it..
and making sure you loosen and tighten the bolts in the right sequence... other than that your good...
another if your going to do this you might as well change the timing belt while your at it
Old 05-14-2006, 09:13 PM
theciv's Avatar
haha foo sho.
thanks alot. i will do this if i end up getting it
looks like a hell of a fun job and good gains considering i have no vtec
Old 05-15-2006, 08:31 AM
brjhnson's Avatar
Default Re: (theciv)
If I go get it from a junkyard what should I look for exactly if I do find the head. For example what pieces
Old 05-15-2006, 08:39 AM
brjhnson's Avatar
Default Re: (brjhnson)
Also I was wandering should I use a D16 VTECH head or a d17 VETCH head
Old 05-15-2006, 05:56 PM
MajinB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brjhnson &raquo;</TD></TR><TR><TD CLASS="quote">Also I was wandering should I use a D16 VTECH head or a d17 VETCH head</TD></TR></TABLE>
OMG D17!
Old 05-15-2006, 06:11 PM
brjhnson's Avatar
Default Re: (MajinB)
calm down i have heard of people using a d16 I was just asking.
Old 05-15-2006, 07:48 PM
well.. if anyone wants my head that i used for that swap im selling it...
Old 03-29-2007, 03:03 PM
jivi's Avatar
Hi newbie here, I have an 2001 LXI gulf specs with D15Y3 engine. Do you think a D17 with Vtec will work as a head swap?
No D15 vtec here in Dubai only a D17 which is a VTI engine has a VTEC.
Will these work also from auto tranny engine then swap to Manual tranny??
Sorry for my ignorance..
TIA
Old 03-29-2007, 03:48 PM
b0yg0tskills's Avatar
Default Re: DIY - DX/LX head swap to EX VTEC (theciv)
what the heck is a es1? and can you feel a big gain in the head swap you did?
Old 03-29-2007, 04:31 PM
Vantage's Avatar
es1 = 4 door.
Old 03-29-2007, 05:13 PM
Curiouz_G's Avatar
is this in the FAQ? If its not, then it should be...
TODD PUT THIS IN THE FAQ!~~~!!
Old 03-30-2007, 11:42 AM
DJaeMac's Avatar
i was wondering how'd you fix the air bubbles in your coolant?...because mine is also doin the same thing....but i also think its boiling....i still don't know if its my headgasket or my waterpump thats causing that because my car overheats like crazy
Old 03-30-2007, 05:23 PM
the 4 door from the 01-05 ex?
Old 03-30-2007, 05:32 PM
to do this swap...do i have to get the ex headers, and intake manifold?
Old 03-31-2007, 04:40 AM
Sanji
toyomatt84's Avatar
Default Re: (b0yg0tskills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b0yg0tskills &raquo;</TD></TR><TR><TD CLASS="quote">to do this swap...do i have to get the ex headers, and intake manifold?</TD></TR></TABLE>
No. Why would you? The mounting points are identical.
Old 04-25-2007, 09:39 PM
blackcivic20's Avatar
do you know of a good place to bye a gasket set from for a resinable price? thats all i need to get
Old 04-25-2007, 09:51 PM
Honda Rules's Avatar
nice very nice
Old 04-26-2007, 04:36 AM
Boilermaker1's Avatar
Default Re: (blackcivic20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcivic20 &raquo;</TD></TR><TR><TD CLASS="quote">do you know of a good place to bye a gasket set from for a resinable price? thats all i need to get</TD></TR></TABLE>
hondaautomotiveparts.com
the head kit is around $120 for all of them
Old 04-26-2007, 07:45 AM
Default Re: (Boilermaker1)
thanks alot i needed that and now i am almost done.
Old 04-26-2007, 10:14 PM
does anyone know what the black round thing is that is on the left side of the engine, wires would usually come down with the ones wraped in the blue and do you need it because i dont see it in this pic.
thanx.
Quick Reply: DIY: DX/LX head swap to EX VTEC
