Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 v6 manual transmission gone to shiii!
Old Oct 6, 2008 | 05:21 PM
SIDEXIT's Avatar
Default 03 v6 manual transmission gone to shiii!
so my transmission finally went out after signs of going out. my shifter can will no longer go into its gears. i don't know whats the problem. my clutch feels soft so i tried bleeding it but no dice.
the only time i can drive it is if i start off on 1st gear by putting it in with the car off, but that's just it.
does anyone know what might be the problem before i take it to the dealer before hand?
Old Oct 6, 2008 | 05:24 PM
SIDEXIT's Avatar
and from talking to people and their guesses they say it might be the throw out bearing, pressure plate, or flywheel.
just a guess
Old Oct 7, 2008 | 03:55 PM
SIDEXIT's Avatar
anyone?
Old Oct 7, 2008 | 09:54 PM
p10hlm's Avatar
Default Re: (SIDEXIT)
friction disk is toast
Old Oct 8, 2008 | 09:40 AM
SIDEXIT's Avatar
will that cost alot?
Old Oct 8, 2008 | 10:12 AM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIDEXIT &raquo;</TD></TR><TR><TD CLASS="quote">will that cost alot?</TD></TR></TABLE>
It's a clutch replacement, call around your area for accurate quotes on a clutch job/replacement including throwout bearing
Old Oct 8, 2008 | 07:45 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">It's a clutch replacement, call around your area for accurate quotes on a clutch job/replacement including throwout bearing</TD></TR></TABLE>
Should call a decent import shop first. Could be the difference between $300(what a local, reputable speed shop charges for taking the trans off/replacing it) and $1500 from a scamming dealership or typical repair shop because they just don't feel like going through the ordeal. I can't believe shops charge so much for a clutch job, I have a couple friends who do it for $75 and it takes them maybe two hours.
Old Oct 9, 2008 | 03:41 PM
SIDEXIT's Avatar
turned out to be the slave cylinder. but they say they see alot of dust in the tranny so they might find another problem. they'll check up on me tomorrow. i hope its nothing big!
Old Oct 9, 2008 | 04:22 PM
Probably shavings from the shitty third gear they acknowledge is bad, but won't fix even though they came out with the TSB after half of the cars were out of warranty
Old Oct 12, 2008 | 05:23 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIDEXIT &raquo;</TD></TR><TR><TD CLASS="quote">turned out to be the slave cylinder. </TD></TR></TABLE>
Do you mind telling us how many miles on your car?
Old Oct 13, 2008 | 04:23 AM
SIDEXIT's Avatar
Default Re: (George Knighton)
about 106,xxx
Old Oct 13, 2008 | 05:43 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIDEXIT &raquo;</TD></TR><TR><TD CLASS="quote">about 106,xxx</TD></TR></TABLE>
Thanks. I have 80+ on my 2006 Accord, so I wanted to have an idea. :-)
If it's just the clutch, it should not cost that much.
If it's the whole transmission, you probably want to consider a used TL-S six speed entire unit, since it'd come with an LSD. You'll have to decide among yourselves, you and your mechanics, whether or not it's worth the risk buying something used.
Old Oct 13, 2008 | 12:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. I have 80+ on my 2006 Accord, so I wanted to have an idea. :-)
If it's the whole transmission, you probably want to consider a used TL-S six speed entire unit, since it'd come with an LSD. You'll have to decide among yourselves, you and your mechanics, whether or not it's worth the risk buying something used.</TD></TR></TABLE>
It's the CL-S George
And as far as I know, the CL-S 6 speed doesn't really have the synchro or shitty third gear problem, so that's something you don't have to worry about.
Old Oct 13, 2008 | 12:48 PM
H-T Order of Merit
Default Re: (Uncle Ben's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben’s &raquo;</TD></TR><TR><TD CLASS="quote">
It's the CL-S George </TD></TR></TABLE>
Is it? I thought people were putting the 2006 and 2007 TL-S six speeds in.
Old Oct 13, 2008 | 12:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Is it? I thought people were putting the 2006 and 2007 TL-S six speeds in.</TD></TR></TABLE>
The 3.5 engines won't work with our trans, so I'm assuming the new TL-S trans won't work with our engines.
VeeSykkz
Jan 26, 2016 08:39 PM
vlc92189
Aug 30, 2006 11:10 AM
mr_magoo
Nov 3, 2005 08:50 AM
HS2G
Aug 22, 2004 07:34 AM
integRated109
Jul 4, 2002 01:53 PM
