Injector Pulse Noise
I have a turbo ls/vtec that has 1000cc rc injectors. The car puts about 505whp to give you an idea. When the car was built I had thought I was injector noise but then some people are telling me that it might be my head. Or maybe needing a valve adjustment. The noise is not crazy loud like something is broken but you can still hear it. Do yall have injector pulse noise?
1000cc injectors at idle are opening/closing very slowly. i doubt you are hearing that over the valve train noise.
even if its not at idle the ammount of engine/valve train noise on a b-series cylinder engine is alot. what you may be hearing is just the valve train working away.
do a valve adjustment and see if what you are hearing goes away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">1000cc injectors at idle are opening/closing very slowly. i doubt you are hearing that over the valve train noise.
do a valve adjustment and see if what you are hearing goes away.</TD></TR></TABLE>
wouldnt they be opening and closing as fast as possible for a very low pulse width because at idle fuel requirements are very minimum on those sized injectors.
