rex is jacked up
Old Oct 4, 2008 | 08:12 PM
ls-crx-si-91's Avatar
Default rex is jacked up
yo can anyone help i bought and ls rex and it starts up fine but after you start driving it it idles weird and it also is really slow for being an ls rex
Old Oct 4, 2008 | 08:15 PM
Mr. Giggles's Avatar
Default Re: rex is jacked up (ls-crx-si-91)
Tro a b16 TRanny in er and youz will be racin like dat dem der v8s..
88YellowRexSi's Avatar
Check the timing... elaborate on "idles weird"...
Old Oct 4, 2008 | 08:20 PM
Default Re: rex is jacked up (88YellowRexSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88YellowRexSi &raquo;</TD></TR><TR><TD CLASS="quote">Check the timing... elaborate on "idles weird"...</TD></TR></TABLE>
<FONT SIZE="5"><FONT COLOR="red">IT SKIPS FROM 1,000-10,000!!!!!!!! </FONT></FONT>
Old Oct 4, 2008 | 08:39 PM
like when i start the car it ildes at about 1ooo like its supposed to but than when i start driving it the idle goes up and back down some times like idk also it has no map sensor i admit it is a little ghetto but i only paid a grand for it thanks for your help
Old Oct 4, 2008 | 08:47 PM
You Are Very Welcome Sir.
Old Oct 4, 2008 | 11:17 PM
Pandor's Avatar
So you are running the engine withouth a map sensor? And you are expecting it to run fine?
Not to sound harsh, but I would suggest you hook everything up like it's supposed to, then check you vacuum lines and clean iacv.
If it's still not running fine, then ask questions.
Old Oct 4, 2008 | 11:22 PM
D16SiHatch's Avatar
Default Re: rex is jacked up (Pandor)
yea hook up the map, whether you use the one thats on the ls tb, or the factory one on the firewall, use ONE of them.
as far as idling weird. these will be your friend
How to clean your IACV
https://honda-tech.com/zerothread?id=1575913
How to clean your FITV
https://honda-tech.com/zerothread?id=1564019
Old Oct 5, 2008 | 05:39 PM
Default Re: rex is jacked up (D16SiHatch)
but see with the map i was told the obdo didnt have one so it doesnt matter if its on or not
Old Oct 5, 2008 | 05:58 PM
tico's Avatar
bro it does matter. thats probably why u are idleing weird. hook it up and then tell us whats going on. who ever told u that should be shot for giving false and in-correct information
v.ice1
Jul 4, 2010 09:27 PM
vestalfootball72
Dec 18, 2007 08:11 PM
JDMworld
Jun 14, 2005 03:41 PM
limpy
Aug 10, 2004 11:11 AM
MaNyFacEs
Dec 2, 2002 08:20 AM
