i just put an ls in my crx and need help
i just put a b18b botoom end with a b18a top end into my rex. every thing is hooked up correctly and what not. my problem is that the motor bogs down really bad inbetween 1k and 2500 rpm. after 3k it does just fine. what could it be?
Re: i just put an ls in my crx and need help (tnibourg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnibourg »</TD></TR><TR><TD CLASS="quote">sounds like timing could be out a bit, double check it.</TD></TR></TABLE>
timing is dead on. couldn't be more perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dundulk si »</TD></TR><TR><TD CLASS="quote">most the time it's the map sensor check it first then check to see if your idle screw needs ajusted </TD></TR></TABLE> map sensor has been changed and still the same thing. the idle screw has nothing to do with it running shitty in between 1000-2500 rpm,
NatedoggAZ
11
10-20-2004 09:00 AM
ramz7887
12
11-13-2003 05:45 PM
