Do I need a relay to install more than one amplifier??
Old Oct 4, 2008 | 12:17 PM
0ptimus prime's Avatar
Default Do I need a relay to install more than one amplifier??
Headunit is a Dxz765mp clarion.
I'm wondering if i absolutely need a relay to trigger both amps from the remote wire. I was reading that most amps, to turn on, require 125 mA and that the average headunit supplies 500 mA from a remote lead.
So do i need a relay or could i simply run the remote to both amps via the same remote lead?
Old Oct 4, 2008 | 03:41 PM
fcm's Avatar
fcm
Old Fart
Default Re: Do I need a relay to install more than one amplifier?? (0ptimus prime)
You do not need a relay. 94
Old Oct 4, 2008 | 05:08 PM
imadigitalgod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus prime &raquo;</TD></TR><TR><TD CLASS="quote"> I was reading that most amps, to turn on, require 125 mA and that the average headunit supplies 500 mA from a remote lead. </TD></TR></TABLE>
When I went to school, 125+125= 250, 250&lt;500 so youre good. I know america's schools are in the s**tter but i think i was 'learned' right lol (jk)
Modified by imadigitalgod at 6:18 PM 10/4/2008
Old Oct 5, 2008 | 10:11 AM
Sic_DA_Nine's Avatar
you do not need a relay. just cut the remote wire and distribute it to both amps
Old Oct 7, 2008 | 10:10 AM
Poppins324's Avatar
Like it has been said you dont need a rely.
I find the easiest way to do it instead of running two wires back it to just run the one to amp number one. and then put a second rem. wire in amp number one and run that to amp number two. you will need either two power wires or a distrabution block though. make sure you have two different grounds though.
weekendboost
Audio / Security / Video
Feb 18, 2013 10:18 AM
HiProfile
Aug 27, 2009 10:06 AM
YellowPhoenix095
Feb 3, 2008 07:10 AM
em1woot
Lighting
Jan 4, 2008 07:29 PM
em1woot
Nov 8, 2007 04:42 PM
