Relay life expectancy?
Old Feb 2, 2008 | 10:22 PM
YellowPhoenix095's Avatar
Default Relay life expectancy?
I'm starting my stealth alarm install on my DD and I was wondering how often should a relay be replaced? Yes, I understand when one malfunctions it should be changed, but how about changing it once a year? once every few years? I was thinking something along the lines of like maintainence to keep your alarm functioning smoothly? I mean, I would hate for a relay to go out on me in the middle of the night in the middle of nowhere.
Old Feb 3, 2008 | 06:41 AM
fastcrvi's Avatar
Default Re: Relay life expectancy? (YellowPhoenix095)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowPhoenix095 &raquo;</TD></TR><TR><TD CLASS="quote"> I mean, I would hate for a relay to go out on me in the middle of the night in the middle of nowhere. </TD></TR></TABLE>
well.. i'm sure your car has room for couple extra relays to carry around for when you happen to be in the middle of nowhere. now, if relays inside alarm brain fail, you may have trouble replacing them in the middle of nowhere. if thats a concern, don't wire to kill any vital components through your alarm.
Old Feb 3, 2008 | 07:10 AM
fcm's Avatar
fcm
Old Fart
As long as you are using a good quality relay, it should outlast the car.
Most common cause of relay failure is not installing a diode across the coil terminals, #85 and #86, the diode will limit "arcing" at the contact points.
I have had a pair of, [un-dioded] Bosch relays for the power door locks in my 94LS since it was new, [late 93] and they still work just fine. 94
weekendboost
Audio / Security / Video
Feb 18, 2013 10:18 AM
EARLdaSQUIRREL
Jul 16, 2008 11:12 AM
snapcase318
Oct 15, 2003 10:17 AM
ultimatehonda
Jan 21, 2003 02:43 AM
