50amp relay?
Old Nov 8, 2007 | 09:39 AM
em1woot's Avatar
Default 50amp relay?
Is there a 50 amp relay, if so, what brand makes it.
Because the guy that install my alarm, said that he can install a igintion kill switch but that I needed a 50 amp relay beacause of the power of the igintion.
I tried looking for one but cant find one.
Old Nov 8, 2007 | 09:48 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 50amp relay? (em1woot)
Find a new installer or tell him to quit being lazy. All you need is a standard 20/30 amp relay.
Old Nov 8, 2007 | 10:28 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: 50amp relay? (wrx-killer-Sti-eater)
50 amps is insane! A 30 would work just fine and you can find them all over the place. A 10amp would work if you put in on the main relay's ground wire which can be found to the right of your glove compartment in your EM1. It's the small black wire.
Old Nov 8, 2007 | 01:31 PM
slowSOHCvtec's Avatar
Default Re: 50amp relay? (White Smoke)
Check out an ABB ITE-50H, they were made back in 1976 or so.
Old Nov 8, 2007 | 02:00 PM
em1woot's Avatar
How excatly do I connect a switch to the main relay's ground.
If you can write it out that would be great.
Thanks
Old Nov 8, 2007 | 04:42 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1woot &raquo;</TD></TR><TR><TD CLASS="quote">How excatly do I connect a switch to the main relay's ground.
Thanks</TD></TR></TABLE> You do not need a relay on the PGM-FI Main Relay, [main relay] ground, it is a low current ground, [for injector relays coil only] less the 250mA, a small, [1A at most] SPDT, [on/off] switch will work just fine.
Cut ground lead, install switch, doing it someplace other then right at the relay is probably a good idea.
Oh yea, 50A relay, Brahahahahahahah, as mentioned, find another installer. 94
dgerej2
Audio / Security / Video
Feb 21, 2011 05:48 AM
tyronne1126
Jun 17, 2009 10:30 PM
91sihatch
15
Apr 13, 2009 06:19 AM
manuiacoban
Apr 5, 2009 03:52 PM
0ptimus prime
Oct 7, 2008 10:10 AM
