97 HX really wierd!!!
Old Oct 3, 2008 | 05:19 PM
JLefevers's Avatar
Default 97 HX really wierd!!!
Ok i have been trying to get some info on this subject for awile now without any luck, so maybe somebody could help!!
97 Civic hx (was an auto)
ok we dont a manual conversion using d16y8 intake mani, swaped out the IACV, pedals, using a d16y8 ecu car run's fine just a CEL problem!!
Since we done the swap he have been having a hard time with some CEL when we run the y8 ecu we get a CEl# 45, we picked up a HX manual ecu and get a CEL #41
Been doing some research and it turns out that the Manual HX's use a five wire o2 sensor, while the auto Hx's and most others Dx,EX use the 4 wire.
I am thinking that both codes are related to the o2.
Should we go and try to find a 96-98 Ex,Dx harness and run the 4 wire o2 with the EX ECU. Or run the HX ecu and wire in the fifth wire for the o2?
If wiring in the 5 wire o2sensor is gonna be the fix then what would be the wiring schematics for this project??? Please some og Honda guru's help!!!!
Old Oct 3, 2008 | 05:55 PM
Nic's Avatar
Nic
Default Re: 97 HX really wierd!!! (JLefevers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLefevers &raquo;</TD></TR><TR><TD CLASS="quote">
ok we did a manual conversion using a d16y8 intake manifold and swaped out the IACV, pedals, using a d16y8 ecu car run's fine just has a CEL problem!!
Since we did the swap he have been having a hard time with some CEL's when we run the y8 ecu we get a CEl# 45, we picked up a HX manual ecu and get a CEL #41
If wiring in the 5 wire o2sensor is gonna be the fix then what would be the wiring schematics for this project??? Please some og Honda guru's help!!!!</TD></TR></TABLE>
Code 45=Fuel system too rich or lean
code 41=Primary oxygen sensor heater
You guess on the o2 code's was correct. I would get a 4 wire harness would be the easiest thing to do in my opinion
Good luck.
Old Oct 3, 2008 | 06:20 PM
Burnt Toast's Avatar
Default Re: 97 HX really wierd!!! (Nic)
There is another problem with getting an ex wiring harness and using a 4 wire ecu. The hx valves and vtec work differently thne the ex head. THe vtec crosses over at a much lower rpm then does the ex. The Ex is aroung 4500 and the hx is around 2800. If you use an ex ecu, its going to run alittle funny inbetween 2800 and 4500 rpms. The hx valves also work differently. It doesn't use them all until vtec crosses over.
My advice is to wire up a 5-wire o2 sensor and retain some of your hx gas mileage. You may also ruin into an egr valve problem using the hx ecu since the y8 intake does not have an egr valve. OR, gget an ex head and wire harness to use your ex ecu.
Old Oct 3, 2008 | 06:21 PM
JLefevers's Avatar
oh i knew what the codes where. lol And we are running a 4wire harness (auto HX)
SOME GOOD INFO WOULD BE GREAT!!!!!
Old Oct 3, 2008 | 06:22 PM
JLefevers's Avatar
Default Re: 97 HX really wierd!!! (Burnt Toast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burnt Toast &raquo;</TD></TR><TR><TD CLASS="quote">There is another problem with getting an ex wiring harness and using a 4 wire ecu. The hx valves and vtec work differently thne the ex head. THe vtec crosses over at a much lower rpm then does the ex. The Ex is aroung 4500 and the hx is around 2800. If you use an ex ecu, its going to run alittle funny inbetween 2800 and 4500 rpms. The hx valves also work differently. It doesn't use them all until vtec crosses over.
My advice is to wire up a 5-wire o2 sensor and retain some of your hx gas mileage. You may also ruin into an egr valve problem using the hx ecu since the y8 intake does not have an egr valve. OR, gget an ex head and wire harness to use your ex ecu.</TD></TR></TABLE>
So you think we should run the HX ECU then wire in the 5wire o2. SOunds like a plan but can anybody pull up the wiring digram for this??
Old Oct 3, 2008 | 06:55 PM
IndySporty's Avatar
Dude you're not gonna get much help there, use the search function, there are a slew of wiring diagrams on here.
Old Oct 3, 2008 | 07:47 PM
You need to google for a pdf version of the 96-00 service manual. You should be able to find it and down load it for free. That will give you all the wiring info you need.
Old Oct 4, 2008 | 03:14 PM
BWoolard's Avatar
This is actually my car we are tryin to fix..... also wanted to ask..... the hx ecu does also throw the code for the egr..... is there a way to bypass that or get around it??
Old Oct 4, 2008 | 04:04 PM
JLefevers's Avatar
Default Re: (BWoolard)
Ok seeing as we are using a y8 manifold (which i am guessing does not have a EGR valve) with the manual HX ECU how can we get pass the CEL 12 EGR. some way to do so???
tecatown2091
124
Jan 30, 2013 12:24 PM
1slowcrx
Jul 20, 2006 12:15 AM
RSZero1
Apr 21, 2003 04:54 PM
RSZero1
10
Apr 21, 2003 02:23 PM
