what to do about the pcv???
im putting a 94 integra intake manifold on a 96 motor. what do i do about the pcv hose because the old one(hose) went to the black box by the oil filter and the new motor shows that it(hose) goes to the valve cover??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tophastyle »</TD></TR><TR><TD CLASS="quote">im putting a 94 integra intake manifold on a 96 motor. what do i do about the pcv hose because the old one(hose) went to the black box by the oil filter and the new motor shows that it(hose) goes to the valve cover??</TD></TR></TABLE>
as long as the PCV is going to a vacuum port into the intake manifold you should be good (assuming you're still using a OBD2 valve cover) and if you're using an intake manifold and throttle body a 94 you might experience some idleing problems because only automatic B18b's use the FITV... Manual Integra's use only the IACV
GTEater
Nov 8, 2001 07:49 AM
