Whats the best oil filter?!?!
Old Oct 3, 2008 | 01:24 PM
redline870's Avatar
Default Whats the best oil filter?!?!
whats the best oil filter? i use oem honda filters. are their better ones then oem?
Old Oct 3, 2008 | 01:26 PM
alphalanos's Avatar
Default Re: Whats the best oil filter?!?! (redline870)
OEM is good. Mobil 1, K&N, Wix.
Old Oct 3, 2008 | 02:12 PM
Mingo's Avatar
Default Re: Whats the best oil filter?!?! (alphalanos)
mobil 1 is good but kinda expensive
Old Oct 3, 2008 | 02:14 PM
batallic's Avatar
oem or purolator pure one
Old Oct 3, 2008 | 02:33 PM
redline870's Avatar
i heard s2000 filters from 00-03
SilverAWD's Avatar
Does it really make a difference? Is our engines going to have a longer life with a better oil filter? I use K&N oil filters btw. Its just easier to remove due to that nut design at the bottom of the filter.
Old Oct 3, 2008 | 02:47 PM
redline870's Avatar
Default Re: (SilverAWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverAWD &raquo;</TD></TR><TR><TD CLASS="quote">Does it really make a difference? Is our engines going to have a longer life with a better oil filter? I use K&N oil filters btw. Its just easier to remove due to that nut design at the bottom of the filter. </TD></TR></TABLE> well if one filter allows for better oil pressure then i would say this would lubricate the engine better and yeah make the engine have a longer life
Old Oct 3, 2008 | 03:01 PM
dirtyfivethirty's Avatar
well lets see......proly the filter made for the actual vehicle by the manufacturer of the vehicle..... BTW " parts that almost fit, almost work" - Honda of America
Old Oct 3, 2008 | 04:10 PM
ShinotakuX's Avatar
Default Re: (dirtyfivethirty)
is it ok to get an oil change without replace the oil filter? is it good for another 3000 miles? I did an oil change myself but i had a difficult time removing the oil filter, so I just leave it, but ill definitely change it the next time i do my oil change. is it ok?
Old Oct 3, 2008 | 05:03 PM
unsungfate's Avatar
Default Re: (ShinotakuX)
yes its ok... you wouldn't wanna do it again though.
fram that thing up and cal it a day.
Old Oct 3, 2008 | 05:07 PM
FG2 chilotz's Avatar
Default Re: (unsungfate)
Fram FTW it does the job and its cheap... but if you want piece of mind OEM, K&N or Mobil 1. does the trick.
Old Oct 3, 2008 | 05:10 PM
unsungfate's Avatar
Default Re: (FG2 chilotz)
yes, fram for a 94 gsr FTW
Old Oct 3, 2008 | 05:13 PM
I run FRAM for a 01 RSX oil filters on my B-series great for that increase in oil pressure. Just doo it.....
vtec.dc2
Dec 8, 2011 04:25 PM
RACEPAK
Apr 14, 2010 07:27 PM
redDAinteg
Sep 3, 2007 12:19 PM
216.226.142.95:27016
Mar 13, 2003 06:43 PM
whtrice01gsr
Apr 10, 2002 01:50 AM
