How good is the honda OEM oil filter ?
I been reading on oil filters and how good each filter is and came to a conclusion that the Fram oil filter's are the bottom of the barrel, and the HAMP filter is probably the best filter out there because of its filtration and higher oil pressure. But I don't want to have to order oil filter's from online websites and pay 14+ just for a filter to be shipped to my house.
My question is, how well does the OEM honda oil filter at the dealership perform compared to the HAMP filter ? Also I have read that alot of other people use S2K filters, but why would you use a larger oil filter when in theory it will lower the oil pressure.
What is a good alternative to the HAMP that I can go to the dealership or a local store and get, and which size filter would be ideal ?
Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Get the Honda OEM oil filter that's made for your car. It's just fine, high quality, all you need.
alright, thanks.
alright, thanks.
Re: How good is the honda OEM oil filter ? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Get the Honda OEM oil filter that's made for your car. It's just fine, high quality, all you need. </TD></TR></TABLE>
all honda oil filters are the same besides s2000 and the infamous honda passport
Re: How good is the honda OEM oil filter ? (Lewy. Dee Ayy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. Dee Ayy »</TD></TR><TR><TD CLASS="quote">
all honda oil filters are the same besides s2000 and the infamous honda passport </TD></TR></TABLE>
and the insight
and the insight
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. Dee Ayy »</TD></TR><TR><TD CLASS="quote">all honda oil filters are the same besides s2000 and the infamous honda passport </TD></TR></TABLE>
If, by that, you're referring to the same size, it's not true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">If, by that, you're referring to the same size, it's not true.</TD></TR></TABLE>
yes they are...every accord,civic, element, pilot, crv, oddy, prelude, crx, del sol, ridgeline all use the same filter.. all the same size..
yes they are...every accord,civic, element, pilot, crv, oddy, prelude, crx, del sol, ridgeline all use the same filter.. all the same size..</TD></TR></TABLE>
yup. same filter and crush washer. only the s2000 uses a bigger filter. and insight uses a smaller one. and passport uses a totally different one.
Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight »</TD></TR><TR><TD CLASS="quote">I would just go oem. I wouldn't understand why you would need a after market one.</TD></TR></TABLE>
alternative, application, crv, filter, filters, good, guide, hamp, honda, larger, montclaire, oem, oil, ridgeline, tech
