car wont start/hellp
Old Oct 3, 2008 | 10:28 AM
PITA09's Avatar
Default car wont start/hellp
I HAVE A 1993 HONDA CIVIC EX , WONT START,,,,, BATTERY IS OK, STARTER HAVE 12 V /// HOW CAN I FIX THIS PROBLEM????
Old Oct 3, 2008 | 10:34 AM
HitF8's Avatar
Default Re: car wont start/hellp (PITA09)
is it getting spark? or fuel?
Old Oct 3, 2008 | 12:13 PM
PITA09's Avatar
Default Re: car wont start/hellp (HitF8)
YES , STARTS IF I PUSH IT ND RELEASE CLUTCH............ ONLY WONT START W KEY
Old Oct 3, 2008 | 12:42 PM
HitF8's Avatar
bump
Old Oct 3, 2008 | 02:03 PM
civicwhip's Avatar
a main relay could be the problem!
Old Oct 3, 2008 | 04:41 PM
IB4TL FTW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PITA09 &raquo;</TD></TR><TR><TD CLASS="quote">YES , STARTS IF I PUSH IT ND RELEASE CLUTCH............ ONLY WONT START W KEY</TD></TR></TABLE>
wow ive never heard of this, if my car wouldnt start i wouldnt even think to try it, but it definitely sounds like something in the ignition, quite possibly a relay.
Old Oct 14, 2008 | 09:03 AM
plantmylotus's Avatar
Default Re: car wont start/hellp (IB4TL FTW)
try jumping the clutch safety switch... its at the top of the clutch pedal look for a yellow harness... jump the harness with a paper clip and it should kick out the starter when you turn the key.
Old Oct 14, 2008 | 09:25 AM
SinsEvil666's Avatar
Yes try bypass the clutch safety switch...thats only of the car doesn't even crank with the key...if it does crank and does not start, then its a diff. problem.
Old Oct 14, 2008 | 10:54 AM
Former User's Avatar
If the clutch switch and relay check out as fine, then your ignition switch at position ON (III) may be bad.
onesoejourner
Oct 26, 2011 08:35 AM
numbnuts22715
Jan 30, 2007 10:31 AM
03K24A4EX
May 26, 2006 04:47 AM
jax si
May 25, 2005 03:35 AM
