obd1 gsr into 99 civic si
Old Oct 2, 2008 | 06:10 PM
nanagsr's Avatar
Default obd1 gsr into 99 civic si
I have a 99 civic si which was theft recovery my motor is gone and I'm thinking of swapping my obd1 b18c1 in it what do I need???
Old Oct 2, 2008 | 06:23 PM
nanagsr's Avatar
Default Re: obd1 gsr into 99 civic si (nanagsr)
please help dudes
Old Oct 3, 2008 | 02:45 AM
b16_sol_707's Avatar
what ecu are you planning on running? You'll need the civic si wire harness, since it connects directly to the ecu.
Old Oct 3, 2008 | 05:22 AM
nanagsr's Avatar
I was planning on using the p72 with the jumper. heard I will need mounts to .do you know?
Old Oct 3, 2008 | 05:44 AM
you'll need the ek mounts. I think I have a set. lmk if you're interested.
Old Oct 3, 2008 | 03:51 PM
nanagsr's Avatar
yes I do how much? do you know if I can use the obd1 wire? or do I need ek wire?
Old Oct 4, 2008 | 12:54 AM
Default Re: (nanagsr)
you'll need an ek wire harness. I may have one of those as well, but I have to talk to my brother about it.
Old Oct 4, 2008 | 05:06 AM
BrianFreels's Avatar
will you have to upgrade your sensors to obd2 sensors or will obd1 sensors work?
Old Oct 4, 2008 | 07:31 AM
I just dropped a civic type r (obd2) motor into a del sol (obd1) and didn't have to change anything.
ed6nate
Nov 9, 2018 11:28 AM
kaoticstyles
Jun 20, 2008 03:30 PM
dank24
Jun 18, 2006 03:40 PM
GSRHATCH187
Oct 23, 2003 10:22 AM
IDriveHonda
Oct 13, 2003 03:37 PM
