How do you get rid of the valve gap ticking noise?
Old Oct 2, 2008 | 05:47 AM
chickenwing's Avatar
Default How do you get rid of the valve gap ticking noise?
I have opened up my valve cover like 5 times now in my quest to minimize the valve ticking noise on my d series motor.
I have adjusted from 0.009 and 0.011, 0.008 and 0.010, and 0.007 and 0.009 and still there is a slight ticking I find abnormal.
I set the cylinder on DTC and adjust both intake and exhaust with a feeler gauge with a slight drag on the feeler.
What specs do you use and what is your process? could having a competition cam, hd valve springs and titanium retainers have something in contributing to the ticking?
Old Oct 2, 2008 | 05:55 AM
00b20vtecoupe's Avatar
Default Re: How do you get rid of the valve gap ticking noise? (chickenwing)
every honda ticks especially if you have a built head...
Old Oct 2, 2008 | 05:56 AM
94delsoltypeR's Avatar
ya make sure you dont have any performance stuff under there, that happened to me with my ITR motor (for sale) we adjusted it 3 times before we got it right, keep at it! good luck
Old Oct 2, 2008 | 06:04 AM
Default Re: How do you get rid of the valve gap ticking noise? (00b20vtecoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b20vtecoupe &raquo;</TD></TR><TR><TD CLASS="quote">every honda ticks especially if you have a built head... </TD></TR></TABLE>
you got to be kidding.
i only put like no more than 400 miles on the motor and tranny so far after the complete rebuild.
Old Oct 10, 2008 | 06:08 AM
start up at cold is not bad but once warm up a tad louder and after it is less again.
Old Oct 10, 2008 | 08:30 AM
instrument's Avatar
thats normal, aim for the low end of the settings then.
a bit of tapping is to be expected, and acceptable ticking is purely subjective, listen to any of your friends cars and see if its similar, you may have unreasonable expectations, at least you'll know what you should expect.
Old Oct 14, 2008 | 02:52 AM
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">thats normal, aim for the low end of the settings then.
a bit of tapping is to be expected, and acceptable ticking is purely subjective, listen to any of your friends cars and see if its similar, you may have unreasonable expectations, at least you'll know what you should expect.</TD></TR></TABLE>
yeah i got it adjusted to the low end of the specs.
maybe take a short video so you guys can confirm whether or not to worry.
the Y7 did not tick as much but it had over 160K miles.
Old Oct 14, 2008 | 03:13 AM
tegboy 195's Avatar
i know the tapping you are on about. my b16a2 does it when cold but by the time it's warm you can't really hear it and when it's driving you can't hear it all
Old Oct 14, 2008 | 05:00 AM
koa's Avatar
koa
Default Re: (tegboy 195)
i thought i heard to much ticking also. i adjusted the valves four times. Then one day i found out it was a rod bearing
Old Oct 14, 2008 | 05:20 AM
TayTeg91's Avatar
r u adjusting your valves when its hot or cold?
Old Oct 14, 2008 | 07:29 AM
jdmracer12's Avatar
it could be possible that the noise your hearing is coming from the fuel injectors. hondas are known for thier loud injectors. just a thought....
Old Oct 14, 2008 | 07:49 AM
alphalanos's Avatar
Default Re: How do you get rid of the valve gap ticking noise? (jdmracer12)
Mine ticks when cold then fades. y7 141,000mi. I was going to say your valvetrain is damn clean. Mine looks like someone hit it with a flamethrower.
Old Oct 14, 2008 | 08:54 AM
Mashimaro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chickenwing &raquo;</TD></TR><TR><TD CLASS="quote">
could having a competition cam, hd valve springs and titanium retainers have something in contributing to the ticking?</TD></TR></TABLE>
Aftermarket valve-train is usually louder than stock valvetrain from what i've seen so i probably wouldn't worry about it so long as you adjusted your valve-lash according to the cam manufacturer.
if it makes you feel better, my Toda valvetrain sounds like WW3 on cold starts in the morning and doesn't 'quiet down' until the temps get to normal operating. even when it's warm, it doesn't come close to being like stock anymore (and i set the valvelash to 0.2mm cold, according to the Toda recommendations...lol!)
Old Oct 14, 2008 | 03:18 PM
Default Re: How do you get rid of the valve gap ticking noise? (Mashimaro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TayTeg91 &raquo;</TD></TR><TR><TD CLASS="quote">r u adjusting your valves when its hot or cold?</TD></TR></TABLE>
COLD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro &raquo;</TD></TR><TR><TD CLASS="quote">
There was no specific instructions for valve lash from competition cams so I'm using honda specs.
Old Oct 15, 2008 | 01:20 PM
Mashimaro's Avatar
There was no specific instructions for valve lash from competition cams so I'm using honda specs.</TD></TR></TABLE>
email them or call them and see if they have a recommended valve-lash setting for their cams.
Old Oct 26, 2008 | 04:56 AM
a HT member sent me a message noting that the cam shaft/springs, retainer was installed incorrectly.
The head and block was stripped and rebuilt. I did the valve lash adjustments after installing the cam, springs and retainers.
This is how i installed them.
Old Nov 8, 2008 | 06:21 AM
competiton cam's valve lash specs are .007 and .009 which I have adjusted to.
Old Nov 12, 2008 | 03:37 AM
still i find it kind of loud once started every morning.
ki0326
Engine Management and Tuning
May 29, 2012 10:43 PM
ArmaanOG
Apr 8, 2009 03:16 AM
B18C_EJ8
Jun 4, 2007 05:10 PM
2point3h22lude
Aug 11, 2005 10:10 AM
Tony C
Jun 29, 2004 08:14 AM
