Transmission & Drivetrain Gearboxes, Differentials, Clutches
93 del sol wont shift , i hope this is a known problem
Old Oct 1, 2008 | 04:37 PM
fastrc2's Avatar
Default 93 del sol wont shift , i hope this is a known problem
ok so my wife has a 1993 del sol si. it has 180,000miles on it, and it has had a dealer fluid change done about 25-30k ago tops. what the transmission does is once in a blue moon, but tends to be when colder, first start of the day, pull out of the parking space, put it in drive and pull out onto the road, once over about 10 mph, there is a relatively loud, but not very loud whine. it does not shift out of first gear. its as if you put it in LOW on the selector, but it whines, then she decelerated for a light, [ thinks she heard the tires squeal or chirp] but i dunno if i believe her, and waited at the light, then went ahead, it whined, didnt shift, she on both accelerations wen to like 3500 or 4000 rpm, and was lightly accelerating, and then it shifted fine, the whine stopped, and the whole rest of the 20 mile trip to work and back stop start go all gears then its fine, and it only does this rarely, it hasnt done it for 8 months, but prior to that it did it 2 weeks prior to that. today, when it did it, it wasnt all that cold, about 55-60 outside and the 8 months prior to that it was super cold, right about 0 degrees! i have checked the throttle cables adjustment, per the honda service manual, and it needed a slight adjustment, so i did, and that was done a year ago or so. the car is driven respectfully, its not hot-rodded, or riced or anything, jst a good old reliable daily driver. i work in a shop, and i talked to some hgher up guys, and the only thing we could think of would be that some sliding shuttle valcve, or some other valve that affects the governor pressure has worn some, and it vibrates, and doesntlet it shift. its weird, whatever it is, once it lets the car shift the noise is gone, instantly. YES the fluid is full and good.
Old Oct 1, 2008 | 06:06 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 93 del sol wont shift , i hope this is a known problem (fastrc2)
I was told old cold seals will do this, allow pressure to bypass and not engage the clutch packs.
Need to run a pressure check on all ports and follow the factory manual.
Old Oct 2, 2008 | 02:38 PM
fastrc2's Avatar
Default Re: 93 del sol wont shift , i hope this is a known problem (Mista Bone)
well my problem, is that i followed the factory manual, and it points to the modulator valve, but f i put guages on it, i have to go that way, with guages for months, because it doesnt do it all the time. it probably wont do it again for at least a month.
TCzLEGACY
Jan 31, 2013 10:13 AM
AtOmIc_EG2
May 20, 2011 04:37 PM
oakandantlers
Jan 3, 2011 07:15 AM
fastrc2
Oct 5, 2008 06:39 PM
fastrc2
Dec 8, 2007 10:14 AM
