Victor X manifold and 76mm throttle body?
Old Sep 30, 2008 | 10:25 PM
HotboxedTypeR's Avatar
Default Victor X manifold and 76mm throttle body?
Can a Victor X manifold be port matched to a Blox 76mm throttle body w/o interfering with the Idle Air Control Valve? If yes, will it run correctly?
Old Oct 1, 2008 | 12:04 AM
V-SPEC 1's Avatar
Default Re: Victor X manifold and 76mm throttle body? (HotboxedTypeR)
yes. I have that setup but using the RPM throttle body.
Old Oct 1, 2008 | 03:28 AM
DaveF's Avatar
Default Re: Victor X manifold and 76mm throttle body? (V-SPEC 1)
for what its worth, you really dont need an iac at all, the idle can be adjusted with the tune
Old Oct 1, 2008 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">yes. I have that setup but using the RPM throttle body.</TD></TR></TABLE>
Did you modify your IAC?
Old Oct 1, 2008 | 08:39 PM
Coreymdean's Avatar
i ported mine out to 75mm and there was some room left for the iac to work properly, not a lot but enough for that. I still disconnected my iac and like it much better without it on there at all
Old Oct 1, 2008 | 11:53 PM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotboxedTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
Did you modify your IAC?</TD></TR></TABLE>not at all. Idle is like stock
Old Oct 2, 2008 | 01:42 PM
jdm inc's Avatar
Default Re: Victor X manifold and 76mm throttle body? (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">for what its worth, you really dont need an iac at all, the idle can be adjusted with the tune</TD></TR></TABLE>
can the s300 b tuned without and iac?
Old Oct 3, 2008 | 11:08 AM
Coreymdean's Avatar
Default Re: Victor X manifold and 76mm throttle body? (jdm inc)
yea..... i tune mine with s300 and no iac
Old Oct 3, 2008 | 01:33 PM
jdm inc's Avatar
Default Re: Victor X manifold and 76mm throttle body? (Coreymdean)
ok thanks cuz i been having nothing but trouble on my iac and im running the s300.
Old Oct 3, 2008 | 05:16 PM
23hatchturbo's Avatar
i ported mine to 77mm for a 1mm step and im running the blox 76mm throttle body victor x with iac no problems proubly over kill though. thats what my tuner said, what do you guys think. But ya can be done with no problems
Old Aug 12, 2010 | 07:18 AM
rollinjdm's Avatar
im running the victor x and 76mm throttle body but havnt ported the intake yet it needs it but i just threw it on there. i think its overkill for the setup i have. i had a 65mm elderbrock tb on there before. but now im having problems with the throttle cable being to tight or not opening all the way.
magicguy
Jan 30, 2009 02:00 PM
SPD DMN
Apr 17, 2008 12:19 AM
Scud
Aug 9, 2006 09:58 PM
-16V-
Feb 15, 2004 05:54 PM
Civic_95_Si
Aug 8, 2003 10:11 PM
