Main seal leak?
Well after a long time of having clutch problems I think I found the problem.
I did have midnight performance in sacramento remove and inspect my transmission (my car wouldnt go in reverse) they said it was fine, the problem was my pressure plate had a chunk of clutch wedged in it.
well same thing happened to me when i pulled my clutch off today, but I had alot of carbon chunks.
here are pictures of the main seal
tell if you think this could cause a problem?.. my clutch always used to chatter/whine if you slipped it for a smooth take off.. do i need a new seal?
I always replace the rear main seal when replacing the clutch...unless it was recently done...most any reputable shop should do this as well.
It is definitely leaking- but doesn't look like there's enough leaking to contaminate the friction disc, causing a chatter issue.
Replace the seal, inspect the flywheel/clutch parts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">I always replace the rear main seal when replacing the clutch...unless it was recently done...most any reputable shop should do this as well.
Well, I had a Action 6 puck. chattered alot.
so I'm just putting a new oem itr exedy so the gf can drive my car also
do i need to remove that whole assembly to change the seal or can i pop it out and replace as is
thanks for the info
</TD></TR></TABLE>Well, I had a Action 6 puck. chattered alot.
thanks for the info
Use a seal puller or a flat head screw driver and pull it out. Careful to not scratch any of the surfaces.
Lube the new one up and careful drive it in...best is to use a seal driver if you have one, otherwise, just work your way slowly around the seal until it sits flush.
climbengruven
Dec 29, 2005 11:06 AM
