Need help with Transmission FLush !?!?
Old Sep 28, 2008 | 09:49 PM
SingleCamin's Avatar
Default Need help with Transmission FLush !?!?
D15B1
Old Sep 28, 2008 | 10:03 PM
D16SiHatch's Avatar
Default Re: Need help with Transmission FLush !?!? (SingleCamin)
uhh.. pull the drain plug and fill it up through the vss hole
Old Sep 28, 2008 | 10:05 PM
Default Re: Need help with Transmission FLush !?!? (D16SiHatch)
what fluid u use ?
Old Sep 28, 2008 | 10:08 PM
D16SiHatch's Avatar
i used plain jane 10w-30. a lot of people recommend honda mtf and gm synchromesh though i believe. assuming this is a 5spd. i suppose you might have an auto in which case just use normal atf
Old Sep 28, 2008 | 10:15 PM
aint atf for auto tran ..i have 5 speed wich one do you think i should get !?!?!... thanks
Old Sep 28, 2008 | 10:19 PM
D16SiHatch's Avatar
i was saying that in the event you had an auto tranny then you should just use standard atfl, since you didnt specify if it was a 5 speed. i would just use standard 10w-30 and call it a day
Old Sep 28, 2008 | 10:22 PM
Ohhh Lol....one more ? ...how many bottles i need
Old Sep 28, 2008 | 10:29 PM
tico's Avatar
2 quarts of Honda MTF. pull the drain bolt. empty old oil. put bolt back. take off fill bolt. put car on all for wheels on level surface. take off back up switch sensor pour in oil till it trikles out of fill bolt. its like 1.8 quarts
Old Sep 28, 2008 | 10:36 PM
Default Re: (tico)
goood lookin you more helpful then the ugly guy up ther Lol thanks
Old Sep 28, 2008 | 10:52 PM
D16SiHatch's Avatar
Default Re: (SingleCamin)
way to be a dick douche. the vss method works but i forgot that on the d-series the reverse switch is on the top of the tranny, where as on a b tranny the reverse switch is horizontal and near the bottom of the trans.
Old Sep 29, 2008 | 01:10 AM
traxxasx's Avatar
Yea u fukin dick.
Old Sep 29, 2008 | 02:27 PM
Default Re: (traxxasx)
haha thank u
Old Sep 29, 2008 | 02:38 PM
Ep1dem1c's Avatar
this guy is such a douche bag... i can't even understand half the **** the dude says... lol
i bet you are 16 years old aren't you?
gangster to the bone too... right?
LMAO
AND GOD YOU ASK THE DUMBEST QUESTIONS!!!!!
Old Sep 29, 2008 | 03:12 PM
kojack_0's Avatar
Default Re: (Ep1dem1c)
my friends and i use 5w-20 through the main tranny drain bolt.
from d-series.org
i think 10w-30 is too thick for transmission fluid.
Old Sep 29, 2008 | 06:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c &raquo;</TD></TR><TR><TD CLASS="quote">this guy is such a douche bag... i can't even understand half the **** the dude says... lol
LMAO
AND GOD YOU ASK THE DUMBEST QUESTIONS!!!!! </TD></TR></TABLE>
haha Go Look for a life on Ebay U BISh haha keep doing what you do i love haters Hi hater
Ritchie
Feb 22, 2011 07:11 PM
kenny7231
Aug 13, 2008 10:30 PM
phi phi
Oct 6, 2005 09:37 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
Jaydeep
Oct 1, 2003 03:54 PM
