misfire but no hesitation or symptoms??
Old Sep 28, 2008 | 04:58 PM
grjp1988's Avatar
Default misfire but no hesitation or symptoms??
I was crusing on the highway and then I went under a bridge and reved it a little all the sudden I get a cel.. I first though [freak] another problem. because I just got fixing my car from a broken mount bolt and pulled threads in my block and I heard you gotta pull the motor well BS! I didnt have to pull it. Well I get off the highway and my car is running fine not hesistation or ANYthing like that. I figured it was an o2 sensor. I got to autozone for a free check and it says misfire ignition system. I dont know which one was but wtf. I pulled wires and made sure they were on. anyone have any suggestions?? im tired of all the problems I have been having with this car latley
Old Sep 28, 2008 | 05:02 PM
B18ek's Avatar
Do you have an aftermarket distributor?
Old Sep 28, 2008 | 05:06 PM
grjp1988's Avatar
nope but I do have aftermarket wires and ngk plugs but they have only had like 5k use
Old Sep 29, 2008 | 12:17 PM
Dave_B's Avatar
Misfire? Which cylinder?
Also, did you recently wash the engine bay?
Modified by Dave_B at 4:23 PM 9/29/2008
Old Sep 29, 2008 | 12:19 PM
walker111's Avatar
Default Re: (Dave_B)
This is gonna sound wierd....but do you have an aftermarket alt belt? ac? ps? Are they too tight? Replace with Honda belts and readjust.
Old Sep 29, 2008 | 12:26 PM
vinuneuro's Avatar
Default Re: (walker111)
That doesn't make any sense.
Old Sep 29, 2008 | 12:32 PM
walker111's Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">That doesn't make any sense. </TD></TR></TABLE>
I figured you of all people would believe that no aftermarket company could make a belt to compete with the unstoppable Honda of the world.....
If you look at iNET Acura, there's a bulletin about having aftermarket belts causing random misfires. In fact I learned this yesterday with a friend in a 97.
Old Sep 29, 2008 | 01:06 PM
vinuneuro's Avatar
hahaha.
That's really wierd. What's their reasoning with that?
Old Sep 29, 2008 | 06:29 PM
grjp1988's Avatar
Well this all happened after fixing that mount I could have left some metal shavings on the crank sensor. I went to autozone again and they said the cel # was p1337 LEET! somethin with ckf sensor
P1337- Crankshaft Speed Fluctuation Sensor No Signal
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">hahaha.
That's really wierd. What's their reasoning with that?</TD></TR></TABLE>
None. Just said they have came across it more than a few times. Couple friends of mine were bringing back a 97 yesterday and ran in to the same problem....looked it up, they cut the ac and ps belt and never through the code again.
Weird...
Old Sep 30, 2008 | 01:55 AM
Spec R's Avatar
Default Re: (grjp1988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">Well this all happened after fixing that mount I could have left some metal shavings on the crank sensor. I went to autozone again and they said the cel # was p1337 LEET! somethin with ckf sensor
P1337- Crankshaft Speed Fluctuation Sensor No Signal</TD></TR></TABLE>
i just made a thread about this in the tech/misc forum. no one answered.
https://honda-tech.com/zerothread?id=2395041
Old Sep 30, 2008 | 04:28 PM
grjp1988's Avatar
ok here is the problem.. I had metal shavings on the crank sensor and I blew them off PROBLEM SOLVED! another thing that looked weird was when I grabbed the crank sensor plug it felt really loose so people make sure its connected.
Old Sep 30, 2008 | 07:19 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">ok here is the problem.. I had metal shavings on the crank sensor and I blew them off PROBLEM SOLVED! another thing that looked weird was when I grabbed the crank sensor plug it felt really loose so people make sure its connected.</TD></TR></TABLE>
PMed
teg_racer
Mar 7, 2010 10:38 AM
bkmc24
Aug 4, 2007 08:51 AM
ckyskater733
Jun 24, 2006 04:35 AM
jjaskula1
Nov 27, 2005 04:55 PM
92BlackSi
14
Apr 8, 2005 11:00 AM
