problem with engine codes
Old Mar 5, 2010 | 10:34 PM
teg_racer's Avatar
Default problem with engine codes
im working on a 99 integra ls, i replaced the head and everything on it put it all back together. firing order is correct. car starts normal but ticks really bad, check engine codes flash 71, 72, 73, 74. means misfire on all cylinders, if it were misfiring why is the car running. i changed the plugs. new plug wires. new cap. new rotor.. double checked the injector plugs to make sure they were in the correct order, tried a few different firing orders to double check.. but still ticks like a plug getting no spark or missing. no backfiring or anything else.. only thing on the car not adjusted is the tps sensor. would that cause it? and car also is in time. belt and ignition.. any insite would be helpfull. thanks guys
Old Mar 5, 2010 | 10:35 PM
Eran's Avatar
HT White Ops
Default Re: CODES THAT MAKE NO SENSE!!
Have you tried a new distributor?
Old Mar 5, 2010 | 10:41 PM
teg_racer's Avatar
no.. the only other dizzy i have is obd1.. you think thats be best choice?
Old Mar 5, 2010 | 10:42 PM
Eran's Avatar
HT White Ops
Well, you've tried every other ignition component.
teg_racer's Avatar
dizzy never had a problem before.. same one i took off the motor to start with.. and its still sparking to make the motor run...
Old Mar 5, 2010 | 10:46 PM
Eran's Avatar
HT White Ops
Are you sure the distributor isn't key'ed 180 degrees out? It goes on two ways.
Old Mar 5, 2010 | 11:31 PM
teg_racer's Avatar
i tried both ways. but it only goes in one way.. i just tore the guts outa it and used some sensors outa my other one. ill see if it made a diff
Old Mar 6, 2010 | 12:39 AM
teg_racer's Avatar
now its only throwing a cylender3. switched injectors around still cyl3. ran the car. pulled the plug wire. didnt bog down at all. touched it to a ground. its sparking but still missfiring,,, how the hell does that make sense!!!
Old Mar 6, 2010 | 04:32 AM
wrenchez81's Avatar
cam timing? did you adjust the valves?
using a test light see if your injector is firing.
Old Mar 6, 2010 | 06:25 AM
jakobe06's Avatar
Check the compression in cyl 3. Had the same problem where I could pull the plug and would not bog down or anything and ended up my cyl 2 had no compression whats so ever due to burnt valves. Let us know what happens
Old Mar 7, 2010 | 10:38 AM
teg_racer's Avatar
Default Re: problem with engine codes
did the compression test, #1 90psi #2 83psi #3 60psi #4 90 psi
its an ls head so ill just pick another one up for 50 bucks instead of replacing the valves.
really didnt wanna pull the head off.... again.. haha thanks guys
leon1990
Jul 7, 2012 01:00 PM
activar
10
May 22, 2011 06:15 AM
Coltmorris
Jul 13, 2009 11:32 AM
SilverCivic96
Mar 1, 2007 05:07 PM
ED8REX
Apr 25, 2006 09:25 PM
