d16a in crx?
Old Sep 28, 2008 | 07:36 AM
antballs420's Avatar
Default d16a in crx?
a good friend of mine has a jdm sohc vtec d16a in his crx si. right now its running the crx si distributor, intake manifold, and ecu. im trying to help him out n get vtec working. i have a p28 computer and an ecu jumper, we have the d16a intake and exhaust manifolds, injectors along with the distributor. my question is will the p28 run this motor properly? also i noticed that the d16a uses a 1 wire o2 sensor. where as the obd1 z6 uses a 4 wire. will the p28 still recognize the o2 sensor?. thanks
Old Sep 28, 2008 | 07:56 AM
sleepingciv's Avatar
Default Re: d16a in crx? (antballs420)
A JDM d16a??
Look at the stamp on the block next to the left of the header see what it says then let us know.
If ya wanna use the p28 youll need a ecu harness a dizzy jumper harness, a 4 wire o2, you will need obd1 injectors
Old Sep 28, 2008 | 08:58 AM
Default Re: d16a in crx? (sleepingciv)
yeah its stamped d16a. n its vtec. looks just like a z6 has an obd1 engine harness and dist. i know how to wire and change everything. just im confused as to why it has a 1 wire and not a 4 wire o2 sensor. looking for someone who has experience with this motor as i never heard of it.
Old Sep 28, 2008 | 09:11 AM
maybe this will help.
https://honda-tech.com/zerothread?id=1466506
Old Sep 28, 2008 | 09:22 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antballs420 &raquo;</TD></TR><TR><TD CLASS="quote">yeah its stamped d16a. n its vtec. looks just like a z6 has an obd1 engine harness and dist. i know how to wire and change everything. just im confused as to why it has a 1 wire and not a 4 wire o2 sensor. looking for someone who has experience with this motor as i never heard of it. </TD></TR></TABLE>
Do everything as if it were a Z6, trash that 02 and get a 4wire and wire it up.
The p28 will do just fine.
Old Sep 28, 2008 | 09:54 AM
boostedhfrex's Avatar
Default Re: d16a in crx? (SIred91)
^^^^ +1, what he said
Old Sep 28, 2008 | 11:18 AM
Default Re: d16a in crx? (boostedhfrex)
thanks for the input, thats what i figured. anybody know what type of injectors this motor uses? i need to know if i have to remove the resistor box. all i know is that this is supposed to be rare motor and info is limited. i would think that the injectors are the same as the z6 units so removal would be necessary. but im just unsure. is there any way to tell by looking at them?
Old Sep 28, 2008 | 11:54 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antballs420 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input, thats what i figured. anybody know what type of injectors this motor uses? i need to know if i have to remove the resistor box. all i know is that this is supposed to be rare motor and info is limited. i would think that the injectors are the same as the z6 units so removal would be necessary. but im just unsure. is there any way to tell by looking at them?</TD></TR></TABLE> You are going obd1 so obd1 injectors and no box needed
Old Sep 28, 2008 | 01:09 PM
IndySporty's Avatar
Default Re: d16a in crx? (***$nyper)
If you are in doubt, put an ohm meter on an injector, under 5 ohms is resistor box, over 10 ohms is non-resistor box.
powersk8er92
Sep 15, 2009 11:41 AM
trooper0641
34
Apr 23, 2004 12:29 PM
groundedcivic91
Jan 26, 2004 09:08 AM
JBk24crx
Oct 22, 2003 07:57 PM
