14b oil/water cooled?
Old Jul 26, 2002 | 03:40 PM
asianspeed's Avatar
Default 14b oil/water cooled?
does the td05h-14b turbo need to be both oil and water cooled? Or is oil cooled enough? and can the water cooled part be ignored?
Old Jul 26, 2002 | 03:57 PM
Replica_Racer's Avatar
Default Re: 14b oil/water cooled? (asianspeed)
I ignored the water setup.
Old Jul 26, 2002 | 04:03 PM
BuCU's Avatar
It is both oil and water cooler, but the water cooled section doesnt have to be hooked up...but ou will notice quicker spool up with the coolant...
Old Jul 28, 2002 | 12:34 AM
AbaZ's Avatar
On all of my setups using DSM turbos we have used the coolant passage. It is really easy to hook up, and increases the turbo life..
Jeff
Old Aug 7, 2002 | 07:48 PM
asianspeed's Avatar
Default Re: 14b oil/water cooled? (AbaZ)
Do you have any instructions how to do the water lines...if it's that easy, then I might try it.
Old Aug 7, 2002 | 09:25 PM
jdblack1's Avatar
All you need is 10ft (2 5ft peices) of 5/16 coolant hose and 4 hose clamps. First remove the hose coming from the thermostat housing going to the IACV. Then run one hose from the thermo. housing to the turbo. The other turbo line goes back to the IACV. It's easy and takes about 10 minutes. Just be sure and not kink the lines because then your idle will act funny, and the line will be more easily broken.
Old Aug 7, 2002 | 10:16 PM
shadowdawn's Avatar
Default Re: 14b oil/water cooled? (jdblack1)
Using a turbo's ability to be watercooled is nothing but good for spool and the turbo itself :D, I love my water cooled t3/t4e
Old Jan 28, 2003 | 04:30 PM
asianspeed's Avatar
Default Re: 14b oil/water cooled? (shadowdawn)
What size fitting do I need for the 14b?
bob102386
Sep 16, 2021 07:36 PM
worx
Feb 1, 2010 01:33 PM
verbal_assasin
Dec 25, 2005 12:11 PM
Brian_92GSR
Apr 9, 2002 07:21 PM
simike
Mar 29, 2002 10:47 AM
