PLEASE HELP 88' to 00' swap ?!?!?!
Old Sep 26, 2008 | 01:28 AM
88wingshondacrx's Avatar
Default PLEASE HELP 88' to 00' swap ?!?!?!
I have an 88’ crx with a 00’ b16 swap. I converted the stock engine harness (obd-0) to (obd-2) also got a jumper harness for the ecu witch is plugged in to a chipped p28 everything is connected. When I try to start it up with the p28 ecu I’m not getting any fuel to the injectors (there’s gas to fuel bar). But when I us the stock (DOHC ZC) ecu with no ecu jumper harness it will start but not correctly.
I’m stuck and can’t find out what’s wrong with it.
Old Sep 27, 2008 | 08:32 PM
Default Re: PLEASE HELP 88' to 00' swap ?!?!?! (88wingshondacrx)
*Bump*
Old Sep 27, 2008 | 08:36 PM
sleepingciv's Avatar
Ok let see if i have this right
you have a obd0 car
a obd2 engine
and a obd1 ecu
right?
Old Sep 27, 2008 | 08:43 PM
Default Re: PLEASE HELP 88' to 00' swap ?!?!?! (sleepingciv)
Yes thats right.
Old Sep 27, 2008 | 08:46 PM
ok what dizzy are you using?
Old Sep 27, 2008 | 08:49 PM
im using obd2.
Old Sep 27, 2008 | 08:52 PM
need obd1 for the p28
Old Sep 27, 2008 | 09:00 PM
ok i will get an obd1 diz and give it a try.
thank you
Old Sep 27, 2008 | 09:05 PM
no prob let me know what happens, do you have the jumper harness for the dizzy? obd0 to obd1 youll need it
Old Sep 27, 2008 | 09:07 PM
Deetz's Avatar
Crazy Honda Guy
Don't waste your time with a new dizzy....both obdI and obdII models are the same with the exception of one plus and two plugs coming out of it. The colors of the wires are the same and super easy to get plugs from if you need to repin and match them up.
Get a obd0 to obdI ecu wire harness conversion so you can plug the P28 ecu into your original wire harness, and run the 4 extra wires needed for the B16A
Otherwise, the swap is the same as any other B16
I'm running a 2000 model B18C in my crx
Old Sep 27, 2008 | 09:16 PM
Default Re: PLEASE HELP 88' to 00' swap ?!?!?! (Deetz)
^^^ ya that would work also either way ya decide let us know what happens
Old Sep 27, 2008 | 09:18 PM
Im little confused by what your saying, Can you break it down better or a pic would help.
Thank you.
Old Sep 27, 2008 | 09:27 PM
the obd2 dizzy has one plug on it the obd1 dizzy has 2 plugs
no pics but this is obd1 to obd2 same thing almost your just taken your dizzy and maken it have 2 plugs
https://honda-tech.com/zerothread?id=1875909
Old Sep 27, 2008 | 09:31 PM
Deetz's Avatar
Crazy Honda Guy
ok, obd1 dizzy- 2 plugs
obd2 dizzy- one plug
quinton
Dec 3, 2012 06:15 AM
:::SIRll_EJ1:::
14
Feb 18, 2010 04:14 AM
Radyjr
15
Mar 19, 2005 12:30 PM
weraider30
Dec 17, 2004 09:45 AM
